Need diagnosing help on 99 M3 E36, Rough Idle, Cold Start Issues - BMW Forum - BimmerWerkz.com
Old 04-01-2009, 11:39 PM   #1 (permalink)
kazamali is on a distinguished road
Hi Everyone,
I'm posting to a number of forum sites in hopes of getting some good advice on my issues(I apologize if you've seen this already):
First, the data:
-99 M3 E36 Coupe
-99k miles
-Active Autowerke Stage 2 Twinscrew Supercharger (AA intake, stock exhaust)
-All maint/SC work is DIY
-Inspections done on time
-No negative history on the car at all
-No major sensor/equipment replacement (except for MAF)
History:
-Bought the car in '02 (36k miles)
-Supercharged it in '06 (80k miles)
-Ran perfect before SC
-Ran perfect WITH SC for 2+ years
(except the occasional <every few weeks> 1188/1189 CODE with no visible performance effects. just reset it, no biggie)
-Dec '08, Car refused to start/hold idle one nite after a short trip and was dumping mass amounts of fuel, blk smoke/soot out of the exhaust(had to disconnect MAF to limp home)
-tried starting it a few times after that before confirming a MAF issue
-replaced MAF(AA uses an e39 MAF for the higher flow), no change
-replaced Active's calibrator unit (connects between MAF and DME to cap E39 MAF voltage to DME), car finally started
Problems(since above steps):
-On cold start, the engine shudders violently for the first 20-30 seconds, like it can barely hold idle (basically you can hear the clanging of the exhaust because the engine is so out of balance
-if I try to back the car out of the garage in the first minute or two, the idle dives as soon as I hit the gas (like the fuel or air is literally cut when hitting the pedal)
-once car warms for a couple of minutes, idle smooths out, but it feels like the engine "skips" a beat (hard to explain, but it's like a minute hiccup at idle every 10-15 seconds
-if I take a short trip (say a mile or two), stop the engine for a few minutes, then start it again, the idle starts to "hunt" or bounce up and down and then drives rough (like choking for a few minutes)
-on longer trips at freeway speeds, I can feel the engine "skip a beat"
-Hard acceleration can "hiccup" as I hit the higher RPM's (but this problem is not always consistent)
-Engine codes thrown CONSTANTLY: 1188/1189 (fuel control bank1/2 sensor 1), 0170/0173 (fuel trim malf. bank1/2)
Before I nosedive into buying the wrong items (ICV, ECT, O2 sensors-which probably need to be replaced anyway), I wanted to see if all of these issues together point to a smoking gun and can possibly help someone else. Yes, my car is at almost 100k miles and yes some component degradation might have been accelerated due to the supercharger, but I'm hoping someone out there has seen this and thru their own troubleshooting have found the solution. I've walked thru the whole vacuum/intake system with carb cleaner to find a leak, but no joy.
I'm not a beginner mechanic(I put in the SC without any issue), but I'm also not heavily exposed to many varied situations like a pro or forum folks. I've scoured many forums and have tried some non-intrusive stuff thus far. I know this can be the "holy grail" of troubleshooting, so any help would be much appreciated.
Thanks!
-Kazam
kazamali is offline   Reply With Quote
Old 04-02-2009, 01:39 AM   #2 (permalink)
It's a manual tranny, btw
Old 04-02-2009, 06:54 AM   #3 (permalink)
Car: 95 318is -- love the car
talisman318is is on a distinguished road
Get a smoke test done
And hope the source of your issues is at least in part a vacuum leak that can be inexpensively remedied.
talisman318is is offline   Reply With Quote
Old 04-02-2009, 03:30 PM   #4 (permalink)
Sodium Chloride
saltshaker185's Avatar
Car: 95 M3
can you swap the software back and put it to a regular intake to see if its the supercharger or its software?
Old 04-02-2009, 08:16 PM   #5 (permalink)
jmo69's Avatar
Car: 1998 328is 2003 325xi
jmo69 is on a distinguished road
Cleaning the ICV isn't hard but IDK if that would cause all your problems. I cleaned mine at 114K because of bouncing idle but it wasn't as dirty as some I've heard of. At least I know it's loose and free. Just my $.02
Cosmos schwartz metalic Sparco strut brace factory X-brace 55w 6000k HID w/LED angel eyes smoked Lamin-X blacked out sidemarkers,tails and brakelights. DDM smoked corners and pedals. 35% tint all around, Prosport water temp and oil pressure gauges, Home Depot lip, M3 rear diffuser ASC-T delete.
jmo69 is offline   Reply With Quote
Old 04-02-2009, 09:45 PM   #6 (permalink)
Thanks for the replies, guys. I'm going to check the fuel regulator first and then do a smoke test (suggestions from the other forums since I'm using an SC and carb cleaner checks don't work). Once that's done, I'll move on to the ICV and the O2 sensors since, as someone put it, the DME ignores the O2's at warm up since it works in a closed loop mode.
Swapping the software isn't an option as I had to send it to FL to have that done (i'm in San Jose, CA). I highly doubt that's the problem, but I'll keep it on my last resort list.
I'll keep you guys posted on the results.
Old 04-22-2009, 01:53 AM   #7 (permalink)
Need diagnosing help on 99 M3 E36, Rough Idle, Cold Start Issues - FIXED
First of all, thanks to all of those who responded and jarred my brain a bit. I tried the following(and most were due for a change anyway) to no avail:
- Smoke test: All good
- Inspected vacuum lines for kinks: All good
- Fuel Regulator: All good
- Spark plugs: All good
- Inspected/Stetho'd' Injectors: All good
- Cleaned MAF: All good
- Cleaned ICV: All good
- O2 sensors: All good (BTW, use NTK only..other brands are crap)
- Fuel Filter: All good
So I got desperate and just ordered *another* frigging MAF to replace the 3 month old one and guess what? All fixed. I mean ALL fixed. None of the symptoms I described above are present. I'm extremely happy and ticked at the same time, but lessons learned. I'm taking my old(well, the old/new) MAF to the nearest shop and having it tested to see what is wrong.
Again, thanks for the help guys and if you want really good priced parts, go to Auto Parts Warehouse (no, I don't work there) via Microsoft Cashback. You literally get %10 cashback for any purchases there. No joke.
Old 04-22-2009, 10:22 AM   #8 (permalink)
Glad to see you got it sorted!
Old 04-22-2009, 04:00 PM   #9 (permalink)
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
lol yeah i ordered stuff through them... but they sent me the wrong A/c Comp. and wouldn't take it back...
1992 318i Coupe parts car
I am Captain Obvious
Rough Cold Idle Problem...out of ideas.. Blackcatecho 5-Series (E12,E28, E34, E39, E60) 35 08-15-2008 07:02 AM
1997 328i Rough Idle on Cold Start Larry Horne 3-Series (E36) 14 01-25-2006 12:09 AM
2000 328i rough idle when cold. Please help. shawnst 3-Series (E46, E90) 13 01-16-2006 06:14 PM
Rough Idle At Start Only - Once Hot Runs Fine streetdreams 3-Series (E36) 1 11-30-2004 12:55 AM
very hard cold starts+ rough idle ????? jshores7 3-Series (E36) 5 03-02-2004 08:57 PM
