Mysterious electrical problem - BMW Forum - BimmerWerkz.com
Old 08-28-2004, 02:16 PM   #1 (permalink)
vwb_john is an unknown quantity at this point
I have a 1995 325is with 171,000 miles. While I was driving the other night several warning lights came on (check engine, ASC, ABS) they stayed on for approximately 5 min. This morning I started the car (no lights came on as normal) after allowing the car to warm up (10 min), I got in, turned on the headlights & fog lights and the same lights came on. After driving for two blocks, one additional warning light came on (battery charge indicator) along with the battery charge indicator light the radio turned off by itself and the headlights dimmed. This lasted for 10 minutes or so, then the battery light went out, the headlights came back to normal brightness and the radio came back on. Everything was fine until I came to my parking spot (after about 15 min of driving) All the warning lights came back on, the lights dimmied, the radio turned off, and the car started to run ruff, then I turned off the lights and the lights went out but the car still continued to run ruff. I had to get to work so I had no time to investigate. I'm at a loss of where to start looking for the cause. I just purchased the car and it is in fabulous condition aside of this one problem. I would appreciate any help you can give, the sooner the better, since this is my main transportation.
vwb_john is offline   Reply With Quote
Old 08-28-2004, 04:12 PM   #2 (permalink)
B3M2W5i's Avatar
B3M2W5i is an unknown quantity at this point
Send a message via AIM to B3M2W5i
maybe you just need to reset everything with the reset tool
Cashmere Beige Metallic
B3M2W5i is offline   Reply With Quote
Old 08-28-2004, 05:05 PM   #3 (permalink)
quality
Delmarco's Avatar
I had the same exact problem one weekend in July with my 1995 318i. I called BMW and they told me to bring my car in. I did the following day. Apparantly I had $2500 worth of maintance that I needed to do because of those darn lights. Apparantly they all mean something and it is not an error. Also becareful with your timing belts that would set off the "check engine" lights. If you don't fix or replace those right away you could ruin your entire engine block.
Need The Experts-mysterious Electrical Problem??? JonnyM3 3-Series (E36) 6 12-06-2004 07:04 PM
strange electrical problem diadpaku 5-Series (E12,E28, E34, E39, E60) 7 11-09-2004 06:19 PM
E34 1990 Electrical Problem champ.4 5-Series (E12,E28, E34, E39, E60) 0 10-03-2004 03:43 PM
Electrical Problem? akrauss 3-Series (E46, E90) 14 08-11-2003 03:43 PM
