my water pump is stuck and one bolt hole to remove is cracked need help to get it out - BMW Forum - BimmerWerkz.com
Old 03-18-2010, 07:54 AM   #1 (permalink)
AdrianSweitzer is on a distinguished road
Exclamation my water pump is stuck and one bolt hole to remove is cracked need help to get it out
i have a 1992 BMW 318I 4 cylender 5 speed. My water pump recently went out and I am having a heck of a time getting it out. One of the aluminum removal holes is cracked and wont allow me to get a good grip to ease it out with the two bolts. Only one will work to ease it out but bottom is still stuck in place. Any suggestions on how to get the water pump out. It will be greatly appreciated.
AdrianSweitzer is offline   Reply With Quote
Old 03-18-2010, 11:41 AM   #2 (permalink)
online14230 is on a distinguished road
Im guessing you mean the 2 holes where you turn the bolts back in to ease the pump outta the hole?
If so, turn one in about 2 turns and and use a mallet to knock the pump IN THE SAME DIRECTION. This will allow the pump to slowly ease itself outta its home...
Youll find that this is a little time consuming but its definately gonna make it a lot safer on your block.
One more thing: TAP LIGHTLY. The idea is to EASE the pump out... not to break it...
I take NO responsibility for what happens if you F it up as a result of taking this advice. YMMV.
online14230 is offline   Reply With Quote
Cracked Fuel Pump DonJ 5-Series (E12,E28, E34, E39, E60) 4 08-20-2009 04:09 PM
E38 98 or under water pump for non water cooled alternators brand new AlpineSixAndSeven OEM Parts 0 10-12-2007 03:58 PM
540 - Water Leak - Radiator? Exp Tank? Water Pump? windarra 5-Series (E12,E28, E34, E39, E60) 2 06-09-2006 10:13 PM
Stuck bolt, help please! Dactyl 3-Series (E36) 4 04-06-2006 07:38 AM
Water In Spark Plug Hole.. gt325i 3-Series (E36) 2 01-24-2005 01:16 AM
