my problem part 2 .. begging for help - BMW Forum - BimmerWerkz.com
post #1 of 8 (permalink) Old 07-20-2004, 08:12 PM Thread Starter
p3rsian is an unknown quantity at this point
hey whats up
ok so my situation was that i went overseas for 2 months and now that i came back my car feels like a 20hp car.
i changed the sparks , oil , fuel filter but nothing happened.
here is what i did today .. when the car was on i took off each spark wire 1 at a time.. for the 1st one the car turned off after i took it off. i then put it in and took off the 2nd wire... nothing happened ! i mean it felt the same no affects i tried the same with 3 and 4. at the end it seems that 2 and 4 are not creating any sparks. i took out the plugs and it seemed like it was new ..
so what can this be ? is it that electricity box that the spark wires are connected to ? whats the name of that ?
any other possibilities or tests ?
if not i guess i gotta take to a mechanic
p3rsian is offline
post #2 of 8 (permalink) Old 07-21-2004, 01:16 AM
thekid's Avatar
thekid has a reputation beyond repute thekid has a reputation beyond repute thekid has a reputation beyond repute thekid has a reputation beyond repute thekid has a reputation beyond repute thekid has a reputation beyond repute thekid has a reputation beyond repute thekid has a reputation beyond repute thekid has a reputation beyond repute thekid has a reputation beyond repute thekid has a reputation beyond repute
if you have one can get one or rig one up you can test for the spark. Bascially what it is is a screw driver with the handle hollowed out and inside is placed a real basic circuit that will power a light. You obviously put the end of the screw driver at the end of the wire and make a connection and then turn the car on, or if it's running you can do the test then too aswell. However, even though it's a horrible thing to do (j/k) you might need to take it to a mechanic if you have one that you trust. If not they may try and screw you over on this.
thekid is offline
post #3 of 8 (permalink) Old 07-21-2004, 02:29 PM Thread Starter
ok here is what happened i went to the mechanic and he said that the ignition wire and the coil set needs to be changed ? :-S all this for not using my car for 2 months .. wtf
p3rsian is offline
post #4 of 8 (permalink) Old 07-21-2004, 02:53 PM
thekid's Avatar
it's possible. That sounds about right if your not getting any spark at all. A bit of moisture could have found its way in, or a squirel (sp?) or other small rodent. I don't think that the wires are too expensive but as I recall the coils can get a little pricey. But you'll be out a couple hundred at worst, no more so than if you had to be driving the car over the last 2 months.
thekid is offline
post #5 of 8 (permalink) Old 07-21-2004, 02:56 PM Thread Starter
any cheap places to buy these ?
cheapest i found for wires was 163 at bimmerparts
but i cant seem to find the coil pack in any sites all i found was on ebay which is here http://cgi.ebay.com/ws/eBayISAPI.dll?ViewI...ssPageName=WDVW
any other places i can get this ?
p3rsian is offline
post #6 of 8 (permalink) Old 07-21-2004, 02:59 PM
Threadkiller
bitcore's Avatar
bitcore will become famous soon enough bitcore will become famous soon enough
Wires to the coils shoudn't be too expensive.
bitcore is offline
post #7 of 8 (permalink) Old 07-21-2004, 03:11 PM
thekid's Avatar
there a cheap place in Atlanta... I can't remeber what it's called but it's usually between 10-25% cheaper than the stealerships just for the parts.
thekid is offline
post #8 of 8 (permalink) Old 07-21-2004, 03:14 PM Thread Starter
why cant i find coil pack on bimmerparts or pelican parts? all i find it ignition coil /// is this the same thing ?
p3rsian is offline
Erratic Idle / Misfire / Cutting out makdolby 3-Series (E36) 12 02-05-2012 08:57 AM
Smg Problem On 330i johanfunsale 3-Series (E46, E90) 0 02-28-2005 08:33 AM
Drl Headlamp Relay Problem (daytime Running Light) tonyhon 3-Series (E36) 5 01-18-2005 08:42 PM
MY PROBLEM PART 3 ... THINKING OF SUICIDE NOWWWWWW p3rsian 3-Series (E36) 10 07-23-2004 03:29 PM
