my leaking manifold!!! - BMW Forum - BimmerWerkz.com
Old 01-26-2004, 09:05 AM   #1 (permalink)
miss20bmw is an unknown quantity at this point
[COLOR=red]I bought my 1st bmw last june its a 318is coupe 93 it was fine untill two months ago when my manifold started ticking!!! ive had it repaired 3 times now and its just gone again has any 1 got a clue what i could do!!!! ghead
miss20bmw is offline   Reply With Quote
Old 01-26-2004, 09:33 AM   #2 (permalink)
bmwboyuk is an unknown quantity at this point
Send a message via Yahoo to bmwboyuk
first you need to find out what side is leaking is it exhaust to manifold or manifold to block either way it is most likely the gasket which means cleaning and replaceing with new gasket.depending on state of manifold studs they might need to be replaced as well.
bmwboyuk is offline   Reply With Quote
Old 01-26-2004, 10:39 AM   #3 (permalink)
will it be expensive?
Old 01-26-2004, 03:36 PM   #4 (permalink)
if you pop in to your local fast fit centre kwik fit,national tyre,hi q, and find the right person they prob do it for a drink.
Old 01-26-2004, 06:31 PM   #5 (permalink)
EXtech's Avatar
I would certainly have someone competent check it out. Sounds like someone worked on your car before that shouldn't have. Agreed, it certainly depends on exaxtly where the exhaust leak is coming from. If it is coming from the manifold to cylinder head gasket, then you need to determine why. These beemers don't just blow exhaust manifold gaskets for no reason. Somebody has had that manifold offf before you bought it. Either there is a cracked manifold, distorted clamping surface (ie manifold surface or cylinder head surface) or a missing bolt/ improperly torqued. If the leak is coming from the manifold to exhaust pipe connection, then either the pipe is not being installed correctly or there is an issue with the securring hardware. Have it checked out by a quality professional. Don't take it to just any quicky oil/lube place (no comment). What area are you in?
STETT Performance -
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
EXtech is offline   Reply With Quote
Old 01-27-2004, 04:51 AM   #6 (permalink)
Im from North Wales the thing is aswell that everytime i take to a garage i get told something different whats the best type of garage to take it to?
Old 01-27-2004, 08:45 AM   #7 (permalink)
EXtech's Avatar
Do some research with people around where you live who have BMW's. Find out where they have taken their cars to and if they were satisfied. Obviously select a shop that specializes in BMW's.
STETT Performance -
Everything BMW
Plano, TX 75074
469-767-3309
Old 01-27-2004, 09:59 AM   #8 (permalink)
thanks for your help
Old 01-27-2004, 11:26 PM   #9 (permalink)
EXtech's Avatar
anytime.
STETT Performance -
Everything BMW
Plano, TX 75074
469-767-3309
Help< Finally Figured Out Where Coolant Is Leaking BMW-ATI 3-Series (E36) 19 09-08-2008 07:15 PM
Leaking Cabriolet roof boomer2005 3-Series (E21, E30) 3 11-18-2005 03:25 PM
Oil Leaking Under Intake kcosh 5-Series (E12,E28, E34, E39, E60) 5 05-05-2005 08:27 PM
Leaking Coolant uclabruins1996 3-Series (E36) 13 10-30-2004 09:01 PM
leaking gas? spieluhr 3-Series (E36) 8 07-21-2004 02:13 AM
