My door won't open - BMW Forum - BimmerWerkz.com
Old 12-02-2003, 04:47 AM   #1 (permalink)
Eggrolled211's Avatar
Eggrolled211 is an unknown quantity at this point
Recently my driver side door will not open when I click on the alarm.. One click the door unlocks (both doors) but when I try to open the driver door its stuck. I lock and open numerous times still won't open. So everytime this happen I have to BANG on the lever very HARD to losen something? I assume..then if I'm lucky I'll pull the lever and wallah!...this happens like all or most of the time. What is broken? should I have to replace the whole door assembly?
<img src='http://l00062.myspace.com/00062/50/89/62019805_m.jpg' border='0' alt='user posted image' />
Eggrolled211 is offline   Reply With Quote
Old 12-02-2003, 07:14 AM   #2 (permalink)
ex owner/admin
Furious's Avatar
no your lock mech might be broken, if it sounds like somethings happening you might be ok, if you can take the door skin off and see if anything is bent or broken.
Old 12-02-2003, 06:45 PM   #3 (permalink)
whitebeemer328 is an unknown quantity at this point
OPEN THE DOOR AND LOOK AT THE LOCKING PART THAT GOES TO THE DOOR TO THE CAR SLIDE THE LITTLE BAR UP SO IT ACTUALLY LOCKS THEN STICK A SCREDRIVER IN THERE AND UNLOCK THE DOORS THEN PULL THE HANDLE UP AND SLIDE IT FOWARD.IF THATS FINE CHECK THE PART ON THE CAR FOR CORRECT POSTION AND HEIGHT SUMTIMES U BANG IT IT PROBALLYS FREES IT UP AT THE HINGE A LITTLE GREASE ALWAYS HELPS.
whitebeemer328 is offline   Reply With Quote
Old 12-02-2003, 11:24 PM   #4 (permalink)
Thanks! I'll try greasing it.
Old 12-03-2003, 11:48 AM   #5 (permalink)
NyteRyda's Avatar
NyteRyda is an unknown quantity at this point
Send a message via AIM to NyteRyda
i have the same problem with my passenger side door. my dad fixed the problem by spraying some wd40 onto the lock or you can try putting some grease on the lock. hope that helps your problem
<img src='http://img224.exs.cx/img224/3479/nyte4cn.jpg' border='0' alt='user posted image' />
NyteRyda is offline   Reply With Quote
Old 12-03-2003, 11:23 PM   #6 (permalink)
thanks for yall replys and help...greatly appreciated
Door will not open from inside or outside...HELP!!! tylset 5-Series (E12,E28, E34, E39, E60) 20 03-28-2013 07:23 AM
Can't open my doors maci4life 5-Series (E12,E28, E34, E39, E60) 11 06-24-2011 08:11 PM
Keyless Trunk to Open dberger 5-Series (E12,E28, E34, E39, E60) 0 07-15-2004 08:57 AM
i cant open my trunk!!! 88325i 3-Series (E21, E30) 6 04-30-2004 11:18 PM
Open Invitation for a Track Day at Pocono Juryjt North East 2 04-23-2004 03:54 PM
