My 325i is drinking water ! - BMW Forum - BimmerWerkz.com
Old 05-24-2004, 09:07 AM   #1 (permalink)
challe's Avatar
challe will become famous soon enoughchalle will become famous soon enough
I just found out that my 325i is drinking
water ! Just a little over 100 ( swedish miles ) ,,,
But what could it be ?
The m50 Engine is not overheating and it works very well !
Anyone got any idea ?
Challe /
<span style='color:red'>This aint a Car ,, Its Art !........
http://www.race68.com/dca.htm
challe is offline   Reply With Quote
Old 05-24-2004, 09:13 AM   #2 (permalink)
Dahboo is an unknown quantity at this point
I assume that by "drinking water", you mean the coolant is disappearing? This may be a no-brainer, but have you checked for any leaks? How long has it been acting up?
Dahboo is offline   Reply With Quote
Old 05-24-2004, 09:20 AM   #3 (permalink)
challe's Avatar
No leaks as I found !
It have acting like this since I bought it .......
But as I told .. No problems with how the engine work´s !
But the " coolant is disappearing " ( My great English lol-lol )
The owner before me change the Heather ( you know that little
cooler in car - to get hot in winter )
Could it be some "Air"problem ?
Sorry for my bad English - I hope it will be better !
Challe /
Old 05-24-2004, 10:39 AM   #4 (permalink)
Have you tried topping off the coolant?
You should only measure coolant level when the engine is cold.
Bry
Old 05-24-2004, 11:02 AM   #5 (permalink)
challe's Avatar
Hi Autotechnica !
I will do that once more !
yes I only will check the Coolant level when its cold !
Could it be some air in the system ?
Thank you for helping !
Challe /
Old 05-24-2004, 11:07 AM   #6 (permalink)
Originally posted by challe@May 24 2004, 11:42 AM
Hi Autotechnica !
Challe /
It never hurts to check for airlock.
Just unscrew the vent hole (it's the one beside the filler cap, unscrew with a phillips screw driver). Unscrew the filler cap as well. Start the car, turn the heater to full blast. Check the coolant level and make sure it's at the top "COLD/KALT" mark at all times, top off as needed. Once you're done topping off, put the fill cap back on. Leave the vent screw out. You should see the coolant bubbling out of the vent hole. After it stops bubbling screw the vent screw back in. See if that sovles the problem.
Bry
Old 05-24-2004, 11:17 AM   #7 (permalink)
challe's Avatar
I build up a BMW site ,,,
WELCOME TO :http://hem.passagen.se/alpina91/
Old 05-24-2004, 11:19 AM   #8 (permalink)
challe's Avatar
Hi Again Autotechnica !
I will try that way you tell ... Im a shame ...
I did do check for airlock . But not the way you tell !
But I will try that tomorrow in that order you tell !
Thank you very much Autotechnica !
Challe /
Old 05-24-2004, 12:48 PM   #9 (permalink)
CiscoKid's Avatar
check if the cap is tight, and make sure you have a 50/50 mix
Old 05-24-2004, 01:05 PM   #10 (permalink)
challe's Avatar
Hi CiscoKid !
It will be a good idea !
Thank you !
Challe /
Old 05-24-2004, 03:20 PM   #11 (permalink)
Super Moderator
dutchbmw's Avatar
I hope it's not a broken head gasket. Did you see white smoke in your rear mirror?
BMW '96 M3 (SOLD)
June 2005 Car Of The Month!
Originally Posted by Torque
Old 05-24-2004, 03:39 PM   #12 (permalink)
GnnSk8's Avatar
GnnSk8 is an unknown quantity at this point
Send a message via AIM to GnnSk8
if you baught it used it could have overheated before. And when BMW engines overheat they tend to burn coolent because the cap can easily melt. So maybe if you havn't check out carfax. Get your VIN# (open your drivers door and look in the part that is normally closed)
<img src='http://img47.echo.cx/img47/4721/smg2copy0zf.jpg' border='0' alt='user posted image' />
Proud Member of the &quot;Ran away from a cop and got away&quot;x2 Club
Proud Member of the &quot;Pulled over at above 90mph and let off with a warning&quot; Club...<span style='color:red'>bitches</span>
GnnSk8 is offline   Reply With Quote
Old 05-24-2004, 04:13 PM   #13 (permalink)
Super Moderator
dutchbmw's Avatar
Originally posted by GnnSk8@May 24 2004, 11:19 PM
............if you havn't check out carfax. Get your VIN# (open your drivers door and look in..............
It's too bad, Carfax wouldn't work in Europe............
BMW '96 M3 (SOLD)
Old 05-24-2004, 06:37 PM   #14 (permalink)
Carfax wouldn't tell you if the engine overheated either. It only reports whatever the owner reports. He could have crashed the car into a wall, towed it to a shop and had it fixed, car fax wouldn't tell you this.
In simple words, Car fax is only useful to a certain extent.
Bry
Old 05-24-2004, 08:13 PM   #15 (permalink)
MyBimmer3's Avatar
MyBimmer3 is an unknown quantity at this point
Send a message via AIM to MyBimmer3
Another thing is i had a very similar problem to this in my 93 325is and it turned out that by removing the black plastic shroud that covers the radiator i found that the small hose running between the coolant tank and the top of the radiator had a small (1/2 cm) crack that at high pressure ( high speed, high rpms, etc) it would leak coolant that would hit the engine blcok after hitting the fan and being shot onto to engine blcok and it would evaporate with the high heat.
MyBimmer3 is offline   Reply With Quote
VIN check please E30 giz Bimmer Talk/Motorsports Talk 6 07-28-2004 06:02 PM
93 325i Suspension fit on a 92 325i?? BMWStrat 3-Series (E36) 3 03-24-2004 09:03 PM
