My 325 Is Leakin Steering Fluid !? - BMW Forum - BimmerWerkz.com
Old 03-08-2005, 03:09 AM   #1 (permalink)
challe's Avatar
challe will become famous soon enoughchalle will become famous soon enough
Unhappy
Yeahhhh ...
My 325 is leakin Steering Fluid !?
Its a little leak ,, but I have to refill once 3 months ...?
Anyone got the same problem ?
And what I might do ?
Challe /
<span style='color:red'>This aint a Car ,, Its Art !........
http://www.race68.com/dca.htm
challe is offline   Reply With Quote
Old 03-08-2005, 03:40 AM   #2 (permalink)
ex owner/admin
Furious's Avatar
hey challe, where is the leak? check under the car. then if its the hose clamps, which it usually is, check my DIY in the FAQ forum
Old 03-08-2005, 07:35 AM   #3 (permalink)
challe's Avatar
[snapback]306276[/snapback]
THANK YOU Furious !
I Will look around in your DIY FAQ Forum !
Once again Thank you !
Challe /
Old 03-08-2005, 11:15 AM   #4 (permalink)
325isBaby's Avatar
Car: 2005 330xi
Power Steering hoses are a common leak area on BMW's not totally surprised.
Come see me at MySpace
Old 03-08-2005, 02:37 PM   #5 (permalink)
Car: 1993 325i
victorgallas is an unknown quantity at this point
Send a message via ICQ to victorgallas Send a message via AIM to victorgallas Send a message via MSN to victorgallas
Originally posted by challe+Mar 8 2005, 08:35 AM--><div class='quotetop'>QUOTE(challe @ Mar 8 2005, 08:35 AM)</div><div class='quotemain'><!--QuoteBegin-Furious@Mar 8 2005, 03:40 AM
THANK YOU Furious !
Challe /
[snapback]306312[/snapback]
[/b][/quote]
I would recomend you just getting all the new hoses, it will be some 250 on parts, but is just a bolt on tipy of job, and you dont get any leak for some good years..
You are a BMW driver when you become part of the &quot;Ultimate Driving Machine&quot;
Fraude an Fahren
BMW &gt; Bayerische Motorenwerke
Auf Viedersehen der herr
www.clemsonfsae.com
victorgallas is offline   Reply With Quote
Old 03-09-2005, 09:51 AM   #6 (permalink)
pcy
pcy is an unknown quantity at this point
Although buying new hoses is not a bad thing....
But first figure out where the leak is. Spray some degreaser and hose off (clean the area including the P/S fluid reservoir exterior). Then, keep an eye for the seepage/leak area. The possible leakage areas are:
- Gasket on the P/S fluid reservoir cap.
- Clamps on the hoses (from and to the reservoir and to the rack)
If the P/S fluid hasn't been changed in the last couple of years, you may use this opportunity to change the reservoir (remember that the filter is in it), hoses, clamps, and new fluid.
Good Luck.
pcy is offline   Reply With Quote
Old 04-08-2005, 02:30 PM   #7 (permalink)
ragtop guy is an unknown quantity at this point
Send a message via Yahoo to ragtop guy
I think my power steering pump just went up I'm ten miles from home what should I do. There's been a drip drip leak, took it to mechanic, he said he tighted up hoses and put in stop leak and filled the res. That was two days ago. Getting in this afternoon and started whining and you know that out of fluid feeling. Didn't see a puddle underneath but a line of fluid that could have been mine when I parked. Sound like a pump gone up to you. I'm sorry but I see ATF everywhere in the owners manual. Is that Auto Tran Fluid or another type and where can I get it and is the best thing to do is just take it directly to the mechanic's or to the dealership? Thanks in advance.
ragtop guy is offline   Reply With Quote
318is Power Steering Fluid taylor 3-Series (E36) 0 06-28-2005 07:42 AM
Automatic Transmission Fluid / Steering Fluid akbarz 3-Series (E46, E90) 1 08-23-2004 02:04 AM
Power Steering - PS fluid or ATF Jmiller911 3-Series (E21, E30) 2 06-15-2004 09:16 PM
Power Steering Fluid Aether 3-Series (E21, E30) 9 04-14-2004 04:20 AM
