Musty Odor From A/c After Filter Change... - BMW Forum - BimmerWerkz.com
Old 06-30-2005, 05:46 PM   #1 (permalink)
dblmikeusa1 is an unknown quantity at this point
Thumbs up
Help, my car smells like a compost pile! The odor is present when I use the system for the first time of the day. It only happened after I changed the filter. Any ideas what could cause this and a solution?
dblmikeusa1 is offline   Reply With Quote
Old 06-30-2005, 05:49 PM   #2 (permalink)
kestrel325is's Avatar
Car: 1995 325is 5-speed
kestrel325is is an unknown quantity at this point
do you run the fan for a little after you have had the a/c on? When you shut off the a/c, leave the fan run for a bit. There could be concensation inside your vents, and the smell you're probably smelling is mildew.
Or, you could spray lysol into the vents...
kestrel325is is offline   Reply With Quote
Old 06-30-2005, 05:53 PM   #3 (permalink)
I just shut it off. It does sit for a while after shut off and has been a Texas car so the mildew is likely. I was thinking of putting something on the filter to reduce the smell...
Old 06-30-2005, 06:43 PM   #4 (permalink)
I live in oregon, so whenever I'm running my a/c, I shut off the a/c and run the air on full about 5 minutes before I get to wherever I'm going. I had this problem often in my old car, and I found that solved it.
Old 06-30-2005, 07:23 PM   #5 (permalink)
drz
master of his domain
drz's Avatar
Car: zhp
I'll give that a try. I have had something similar happen. Also on a former Texas car.
Turkey Fleet Bond Holder
Fuel Filter change for m42 p3rsian 3-Series (E36) 2 07-20-2004 10:12 AM
Spin-Flow Filter luvinangel Bimmer Talk/Motorsports Talk 6 07-07-2004 05:22 AM
