motor mount replacement - BMW Forum - BimmerWerkz.com
Old 06-30-2003, 03:58 AM   #1 (permalink)
2slow3 is an unknown quantity at this point
Well, the metal motor mount piece on the passenger side is cracked straight through next to the front bolt at the block. am wondering if this is a diy? I am assuming it could be, as long as i have a floor jack for below and some support from above to hold everything steady. anyone ever done it? i can get a new one for about $100. was also told to consider welding, but i can't imagine i'd save a ton of $$ since labor is so expensive ...
what do you think?
1997 328is
black and tan
bone stock, for now!
2slow3 is offline   Reply With Quote
Old 06-30-2003, 04:07 AM   #2 (permalink)
GreenDragon's Avatar
GreenDragon is an unknown quantity at this point
Depends on how adept you are with tools, if you have the tools (or can rent them. I think you can rent a motor winch), but I wouldn't suggest you DIY it. Simply because if the slightest thing were to go wrong you could be in a world of hurt (engine falling, the mount not going in correctly, lifting/moving the engine incorrectly, too much stress on the engine causing other parts to break, etc).
<span style='color:green'>Nobody likes you.</span><img src='http://www.bmw-forums.com/forum/html/emoticons/ph34r.gif' border='0' alt='user posted image' />
<span style='color:green'>Are you experienced, little girl? I want to know what goes on in your little girl world.</span>
<span style='color:green'>I'm the man! I'm bad, I'm so bad I should be in detention. I'm the man!!!</span>
GreenDragon is offline   Reply With Quote
Old 06-30-2003, 05:19 AM   #3 (permalink)
FruityOne's Avatar
FruityOne is an unknown quantity at this point
Send a message via AIM to FruityOne
i wouldnt recommend it either
93 325is - SOLD (white car in sig)
92 325i - 220rwhp/205rwtq (RIP)
02 GSXR 600 - 107rwhp/48rwtq
95 M3 - 220rwhp/205rwtq
President & Founder OF S50 Swap Club
THC the three most powerful letters in my veins...
FruityOne is offline   Reply With Quote
Old 06-30-2003, 07:55 AM   #4 (permalink)
ex owner/admin
Furious's Avatar
typically the motor mounts are an considered one of the easier fixes, granted you have the proper tools. the main ones being a lift and some sort of stragiht lift to jack up the motor while you remove and replace the new motor mount. all that aside the only other problem is that some of the work is done blind. getting the mount in and out is slightly difficult because of space is limited, and the above mentioned blind work. i would however suggest you take it to a mechanic to do it now that i think of it. ive watched my mechanics change them and it appears quite difficult sometimes even though they say different.
Old 06-30-2003, 10:55 AM   #5 (permalink)
Retired administrator
triggrhaapi's Avatar
motor mount replacement, is it a diy?
No. No it isn't.
Addicted to Speed Since 1997
Old 06-30-2003, 11:57 AM   #6 (permalink)
thanks for the input. it didn't look too tough to get to from under the car, but i probably won't risk it. thanks all.
1997 328is
black and tan
Old 06-30-2003, 03:01 PM   #7 (permalink)
ex owner/admin
Furious's Avatar
no problem . lemme know how things went. and by the way was this the cause of your "shudder"? if im glad i guessed right in the other thread.
Old 07-01-2003, 01:08 AM   #8 (permalink)
Well, the shudder has yet TBD. I'm suspecting the mount may not help, although I'm not convinced it's the source. Was reading some other sites and people with similar problems said it was overheating, that if the temp gauge goes above 1/2 way it can cause this problem. Since mine only seems to do it when hot or with the AC on, I'm checking into that too. BUT, I'll have the mount replaced regardless!
1997 328is
black and tan
Old 07-01-2003, 01:51 AM   #9 (permalink)
ex owner/admin
Furious's Avatar
no usually that would be two different problems. you know the old saying, "when it rains it pours" check to make sure your thermostat isnt starting to go bad on you. also check your coolant levels and for any possible leaks in the cooling system
Synthetic Oil and filter CiscoKid 3-Series (E36) 45 04-25-2007 10:50 PM
Replacement Exhaust System Leo J. DeLeon 1,6,7,8 - Series and Mini Cooper 1 07-08-2005 02:45 AM
Replacement Hood Cost For 2000 323?? nmcruser 3-Series (E46, E90) 1 03-21-2005 02:07 PM
'88 528e Engine Replacement JPau 5-Series (E12,E28, E34, E39, E60) 3 03-15-2005 12:34 PM
`87 325ic clutch replacement - fair price? vidsal 3-Series (E21, E30) 1 11-22-2003 01:40 AM
