Motor Cranks But Wont Start - BMW Forum - BimmerWerkz.com
Old 11-22-2004, 06:32 AM   #1 (permalink)
AllEyezOnMe is an unknown quantity at this point
Please help!!
I recently had my transmission rebuilt, I received a call from the mechanic telling me the work was done on the transmission, but now the car wont start. He asked me if I had problems starting the car..I never had this happen.I went and bought a new battery thinking this would help because the car had been sitting for about 6 months before I had the transmission fixed.Is it possible that if the transmission is not installed correctly that would affect the motor cranking but not starting??
AllEyezOnMe is offline   Reply With Quote
Old 11-22-2004, 06:55 AM   #2 (permalink)
IvanB's Avatar
IvanB is an unknown quantity at this point
Originally posted by AllEyezOnMe@Nov 22 2004, 06:32 AM
Please help!!
[snapback]235176[/snapback]
Bad gas maybe or fuel filter clogged from bad gas? Really could be anything at this point if someones been messing with it for a while. When its cranking does it sound like its close to starting at all or does it just crank cleanly.
IvanB is offline   Reply With Quote
Old 11-22-2004, 07:16 AM   #3 (permalink)
Originally posted by IvanB+Nov 22 2004, 04:55 AM--><div class='quotetop'>QUOTE(IvanB @ Nov 22 2004, 04:55 AM)</div><div class='quotemain'><!--QuoteBegin-AllEyezOnMe@Nov 22 2004, 06:32 AM
Please help!!
[snapback]235185[/snapback]
[/b][/quote]
I had a new fuel pump assembly & filter installed about 1 year ago. When it comes to cranking it cranks cleanly.
Old 11-22-2004, 10:06 AM   #4 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Have you checked the plugs in the past year or so.. that might be at fault... or maybe the injectors...
Good Luck,
Les
1997 E36 M3 1990 E30 325i
Old 11-22-2004, 12:16 PM   #5 (permalink)
IvanB's Avatar
Good Luck,
Les
[snapback]235219[/snapback]
if the tachometer bounces when the engine is cranked by starter the ignition system is probably ok.
if not check out your ignition system.
Run Out Of Gas Wound Start (help) p_villa3030 1,6,7,8 - Series and Mini Cooper 1 02-07-2009 05:12 PM
323i Wouldn't Start TRuckee 3-Series (E46, E90) 8 12-04-2005 01:41 PM
Hard Start Becomes No Start 325eXTATIC 3-Series (E21, E30) 3 05-20-2005 05:30 AM
Push Start Button mmzcee 3-Series (E36) 5 02-22-2005 01:27 PM
'93 325i Won't Start 86VFR750R 3-Series (E36) 3 12-05-2004 08:32 AM
