More Problems With My 318 - BMW Forum - BimmerWerkz.com
Old 01-02-2005, 08:32 AM   #1 (permalink)
john_18 is an unknown quantity at this point
Aight so i had a problem with my window motor that didnt work. As soon as I find a motor that works i'll be in business. However my car had been sitting for over a year. So it had a slight amount of hesitation when i cruised around 60 mph. it only shutters for a few seconds then seems to work itself out and is normal again. Welp i changed the plugs and ran a fuel system flush. that helped some but it didnt alleviate the problem entirely. I pulled the codes for my check engine light and came up as the O2 sensor. Could this be a reason why i get some slight hesitation while on the free way? There is no hesitation in stop and go traffic. Or is something else bigger wrong w/ my baby
Alpine White 328 IS, Pioneer Head Unit, Jensen Band pass box, debaffled air box w/ K&N filter, supersprint exhaust. clear corners and side markers, More to come....
john_18 is offline   Reply With Quote
Old 01-02-2005, 09:12 AM   #2 (permalink)
quality
Delmarco's Avatar
[snapback]262526[/snapback]
I think John 318 would have been a better handle for you...get it you drive a 318...
nah...tyhat was corny...
just wanted to welcome you... to the house that BMW built!
Old 01-02-2005, 02:06 PM   #3 (permalink)
yea i used to have a 328 and really havent bothered to change my name
Old 01-02-2005, 04:39 PM   #4 (permalink)
abemcclellan's Avatar
abemcclellan is an unknown quantity at this point
yes i believe that the oxygen sensor would be your main problem. the o2 sensor measures the exhaust gases that reads if it burning rich or lean. then tells the computer to burn more gas or run leaner. this is from my understanding.
abemcclellan is offline   Reply With Quote
Old 01-02-2005, 06:44 PM   #5 (permalink)
woahhhhh........122 posts each
Old 01-02-2005, 11:11 PM   #6 (permalink)
spoolindynamics is an unknown quantity at this point
this is off topic... but on my 93 325i, like wen i push the gas and let go its makes a noise like a belt is hitting or air is being released... i have no clue wat it is?... can you help me?
C:\Documents and Settings\Cabanban Family\My Documents\My Pictures\Car
spoolindynamics is offline   Reply With Quote
Old 01-02-2005, 11:23 PM   #7 (permalink)
350z
Car: 03 Nissan 350z Track
well if you need to change your o2 sensor becuase of the code change it.. i think somewhere in the FAQ section there is a whole write up about what the sensor does and why it will say its done when its not! check that out and run the tests! but the o2 sensor could have something to do with it...
David
**BAKER POW REPORT**
Old 01-03-2005, 06:31 AM   #8 (permalink)
thanks felllas. Before i get my mechanic to call olympus and order one is tehre any other place i should look to purchase a replacement?
Old 01-03-2005, 08:13 AM   #9 (permalink)
93 325i's Avatar
tunermotorsport.com or bimmerworld.com
Complete mod list and pics:
My 1993 325i
Old 01-03-2005, 09:02 AM   #10 (permalink)
bmwcrazy is an unknown quantity at this point
How many miles do you have on your car? If its more than 100k then it should be time to change your O2 sensor anyway.
bmwcrazy is offline   Reply With Quote
Old 01-03-2005, 10:36 AM   #11 (permalink)
yep ive got 124K
Old 01-03-2005, 10:45 AM   #12 (permalink)
is there a reason why tuner motorsport.com doesnt offer o2 sensors for 318's. This sensor is for a 325 i or an M3, would it fit on my 318?
http://www.turnermotorsport.com/html/detai..._ID=11781735499
Climate Control Problems black318 3-Series (E36) 0 02-24-2005 02:00 AM
94 325is Problems sre2114 3-Series (E36) 23 10-21-2004 04:27 PM
