more clutch... - BMW Forum - BimmerWerkz.com
Old 08-03-2003, 10:05 PM   #1 (permalink)
morph's Avatar
morph is an unknown quantity at this point
Send a message via AIM to morph
so, when a clutch "goes out," what is the part/s that go normally? can i buy parts for a more sportier clutch and upgrade the rest over time? i.e. if i buy some parts bavauto.com should i just go all out and replace the whole mechanism or can i just replace the damaged/old parts?
<img src='http://home.earthlink.net/~thefurthestpoint/bimmer.jpg' border='0' alt='user posted image' />
morph is offline   Reply With Quote
Old 08-03-2003, 10:10 PM   #2 (permalink)
lwebb12's Avatar
Car: 2000 M5
lwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond repute
Send a message via AIM to lwebb12 Send a message via Yahoo to lwebb12
well when a clutch "goes out" it is usually the clutch plate itself that is worn. sometime the throw-out bearing can be bad or the pressure plate can break(very rare). when buying a new clutch assembly you get throw-out bearing, clutch plate and pressure plate. you can buy an upgraded clutch assembly if you plan on making increases or driving harder than normal.
Member 150+ MPH club
Member of the 3-Pedal club
Memebr BMW FORUMS V1 CLUB
lwebb12 is offline   Reply With Quote
Old 08-04-2003, 12:04 AM   #3 (permalink)
morph's Avatar
so then it is okay to by a nicer/sportier clutch plate than the factory stuff. i.e. it doesn't effect the rest of the parts if i get a nice plate?
Old 08-04-2003, 12:15 AM   #4 (permalink)
lwebb12's Avatar
Car: 2000 M5
no it doesnt. some sportier clutches have a harder spring tension from the pressure plate which will result in harder clutch actuation. not all of them do though. besides since you have to have the car apart to replace clutch might as well get a sportier one if you can afford it.
Old 08-04-2003, 04:51 AM   #5 (permalink)
morph's Avatar
can you recommend a clutch or two?
Old 08-04-2003, 08:12 AM   #6 (permalink)
GreenDragon's Avatar
GreenDragon is an unknown quantity at this point
Is clutch replacement a DIY?
*sorry to jump in, but this is always good info*
<span style='color:green'>Nobody likes you.</span><img src='http://www.bmw-forums.com/forum/html/emoticons/ph34r.gif' border='0' alt='user posted image' />
<span style='color:green'>Are you experienced, little girl? I want to know what goes on in your little girl world.</span>
<span style='color:green'>I'm the man! I'm bad, I'm so bad I should be in detention. I'm the man!!!</span>
GreenDragon is offline   Reply With Quote
Old 08-04-2003, 08:15 AM   #7 (permalink)
donutchow is an unknown quantity at this point
i wouldn't replace a clutch if you didn't have access to a lift or if you're not 100% sure of what you're doing. it's worth paying the money to get it done.
Founder of the 3 pedal club, the first actual club on BMW-Forums.
donutchow is offline   Reply With Quote
Old 08-04-2003, 11:48 AM   #8 (permalink)
lwebb12's Avatar
Car: 2000 M5
yeah clutch replacement really isnt DIY. you either have to remove the motor. or drop the transmission down. quite labor intensive and you need proper tools. however if you know someone who can do it you can always help them and they wont charge you as much. that is what i did when i changed the clutch in my mule
Old 08-04-2003, 02:16 PM   #9 (permalink)
morph's Avatar
what's a DIY? and is "sach's" a good product?
Old 08-04-2003, 02:18 PM   #10 (permalink)
2.link's Avatar
2.link is an unknown quantity at this point
Send a message via AIM to 2.link
Do it yourself = DIY and if you have a cherry picker just unbolt everything pull it out pull off the old clutch and flywheel get new ones.....then reverse the order....
<img src='http://www.european-forums.com/forums/uploads/post-1-1107198379.jpg' border='0' alt='user posted image' />
Formally known as Asio.
2.link is offline   Reply With Quote
Old 08-04-2003, 02:31 PM   #11 (permalink)
lwebb12's Avatar
Car: 2000 M5
well pulling an engine isnt that easy nowadays. with all the vacuum connections and electrical connections. he does have a 98 bmw so he may want professional help.
Old 08-04-2003, 02:58 PM   #12 (permalink)
2.link's Avatar
True dat..
Old 08-04-2003, 03:09 PM   #13 (permalink)
morph's Avatar
you guys rock. thanks for your help. it is greatly appreciated.
Old 08-04-2003, 08:08 PM   #14 (permalink)
BlackTape's Avatar
BlackTape is an unknown quantity at this point
Send a message via ICQ to BlackTape Send a message via AIM to BlackTape Send a message via MSN to BlackTape Send a message via Yahoo to BlackTape
BavAuto is a RIP OFF
carpartsgo.com is the least expensive place to buy car parts
<img src='http://www.satchmo.com/cashmoney/btymers.jpg' border='0' alt='user posted image' />
<span style='font-family:Impact'><span style='font-size:21pt;line-height:100%'><span style='color:red'> GANGSTA Tape</span></span></span>
BlackTape is offline   Reply With Quote
Old 08-05-2003, 01:47 AM   #15 (permalink)
Retired administrator
triggrhaapi's Avatar
easier said than done, Asio... it's not so simple to get the motor out of the car, even on a '92 like Fruity's...
Addicted to Speed Since 1997
E34 Clutch Switch -- HELP ! ! ! m3driver97 5-Series (E12,E28, E34, E39, E60) 5 10-28-2005 05:22 PM
Clutch Kevin325i 3-Series (E36) 13 08-06-2004 12:09 PM
Problems with M3 clutch after install Autotechnica 3-Series (E36) 20 07-03-2004 07:01 PM
E36 M3 UUC Flywheel Wrong Clutch Becherert 3-Series (E36) 1 03-09-2004 01:39 PM
home-made clutch stop woobiee Picture Showroom 7 02-11-2004 01:14 AM
