Originally Posted by terry12 hey all i'm new here and have a question i'm changing my head gasket because my 94 325is keeps overheating i'm about to remove the vanos then cams then head but i'm working in my driveway and wanted to know if it would be a bad idea to remove the head(to get machined) and keep the block in the car and prep it while outside??also would it be bad to have a mls h/g while n/a until next summer?? |
It should not be a problem to keep the block in the car and get the head machined. In fact I think most people do it this way. Be sure to keep the hood closed and try your best to keep debris or moisture from getting inside the cylinders.
Now seems like a good time to go for a MLS and some ARP studs if you are planning for boost in the future.
