Misfire Fault Code - BMW Forum - BimmerWerkz.com
Old 07-27-2005, 08:34 AM   #1 (permalink)
nookatee is an unknown quantity at this point
Send a message via AIM to nookatee
Ok, so for a little while now I've been trying to decide how to attack this problem. My car didn't pass inspection and even after I cahnged the 02 sensor, I'm still running too rich. I've decided to try to pull the fault codes, except that a.) the manual method of pressing the gas petal five times is really difficult and b.) i think some of the neccessary light bulbs are burnt out. I'm still not sure which light bulbs to buy (there are two different ones at Bavauto.com and i don't want to buy 2X as many light bulbs as I need). Any advice on the light bulbs would be valuable.
This post however, is to determine if there's a way to find out if one of my cylinders is misfiring, perhaps by hooking something up to the cylinder. I noticed a little bit of oil in the spark plug well (blown valve cover gasket) over one of the cylinders. I have a feeling this could be causing a misfire because it looks like the oil in the well is seeping onto the spark plug.... :-/
Let me know what y'all think.
Ramy
nookatee is offline   Reply With Quote
Old 07-28-2005, 01:27 AM   #2 (permalink)
drz
master of his domain
drz's Avatar
Car: zhp
Get the codes read at Autozone. Then come back and tell us what's up. The codes will indicate if a misfire has been detected. ALso, if you have them read, you don't have to worry about the bulbs. Replacing components in the instrument panel is a pain in the neck anyways. DOn't go there unless absolutely necessary.
Turkey Fleet Bond Holder
Old 07-28-2005, 07:59 AM   #3 (permalink)
I've heard that Autozone only does OBDII fault code readings. My '93 is an OBDI
Old 08-01-2005, 01:29 AM   #4 (permalink)
Car: 1993 325i
victorgallas is an unknown quantity at this point
Send a message via ICQ to victorgallas Send a message via AIM to victorgallas Send a message via MSN to victorgallas
Ramy
[snapback]365450[/snapback]
If you hyave oil leaking into your spark plug recess due to old valve cover, this will cause missfire, loose power and make your engine run shitti. The oil accumulates on the recess and then it floods the spark plug, and then the plug looses contact.
Raplce the valve cover gasket, not a hard job, then clean all plugs and electrical contacts good.
If spark plugs are old, just replace them .
You are a BMW driver when you become part of the "Ultimate Driving Machine"
Fraude an Fahren
BMW > Bayerische Motorenwerke
Auf Viedersehen der herr
www.clemsonfsae.com
victorgallas is offline   Reply With Quote
Strange Fault Code ben_t 5-Series (E12,E28, E34, E39, E60) 0 04-02-2005 06:53 AM
Dwa/ews Input Peake Fault Code? jday 5-Series (E12,E28, E34, E39, E60) 8 02-04-2005 09:19 AM
fault code boblynn1 1,6,7,8 - Series and Mini Cooper 1 09-28-2004 10:43 AM
