Misfire cylinder 1 - BMW Forum - BimmerWerkz.com
Old 04-11-2004, 08:35 AM   #1 (permalink)
Mrcapitan is an unknown quantity at this point
I am curious if any of you guys had this check engine light came on and the error read out as "misfire cylinder 1" and the engine will start shaking until its turn off reset it and turn it back on will run smooth again, so far I have replaced all spark plugs with platinum 4 and also replaced the coil on cylinder 1, what in the world is going on? ghead
Mrcapitan is offline   Reply With Quote
Old 04-11-2004, 09:50 AM   #2 (permalink)
Eggrolled211's Avatar
Eggrolled211 is an unknown quantity at this point
uh oh platinum 4 eh?? thats what I've put in has the same problem everynow and then....I'm taking them plugs out. I heard they do stuff like that, I personally think it sucks. Good luck fixing ur car.
<img src='http://l00062.myspace.com/00062/50/89/62019805_m.jpg' border='0' alt='user posted image' />
Eggrolled211 is offline   Reply With Quote
Old 04-11-2004, 10:40 AM   #3 (permalink)
bimmerfan620's Avatar
bimmerfan620 is an unknown quantity at this point
Send a message via AIM to bimmerfan620 Send a message via Yahoo to bimmerfan620
don't know... misfiring could be from a number of things, but if it doesn't do it all the time then it sounds like something electrical for sure.
FOUNDER of the BMW-Forums Michigan Club
<span style='color:green'><a href='http://www.cardomain.com/memberpage/458339' target='_blank'> Car Domain UNFINISHED </a> </span>
<img src='http://www.bmw-forums.com/forum/uploads/post-4-1078289877.jpg' border='0' alt='user posted image' />
bimmerfan620 is offline   Reply With Quote
Old 04-11-2004, 03:25 PM   #4 (permalink)
I recently changed coil 5 I have seen different forums stating that misfire on coil one is really misfire on coil 5, I will give this a shot so far since this moorning is running smooth we'll see?
However I will keep your guys post it.
Old 04-11-2004, 03:28 PM   #5 (permalink)
leibniz is an unknown quantity at this point
I would tend to agree with Eggrolled211.
From what I have read on these boards, there seems to be a general agreement that the [Bosch platinum +?] 4s are more troublesome than the cheaper +2s or equivalent. I know it's costly for the +4s, but for the price of a half dozen +2s you could test that theory.
I also have the 1997 328i and haven't had that problem [knock on wood]
leibniz is offline   Reply With Quote
Clutch Has No Resistance...need Help!! SDSUe36 3-Series (E36) 16 04-06-2011 01:48 PM
Cylinder 3 Misfire, Related To Air Mass Meter? jasonharlos 3-Series (E46, E90) 8 10-06-2009 10:13 AM
5 Series Engine Misfire jtroitino 5-Series (E12,E28, E34, E39, E60) 6 03-16-2006 04:19 PM
Misfire Cylinder 5 gthoman 3-Series (E46, E90) 19 02-23-2005 02:07 PM
