Metal To Metal Noise When Doing Left U Turn - BMW Forum - BimmerWerkz.com
post #1 of 12 (permalink) Old 11-06-2004, 08:29 PM Thread Starter
dblmikeusa1 is an unknown quantity at this point
Thumbs up
I have recently discovered that when I do U turns or sharp lefts I get a grinding noise towards the front right of the car; it almost resembles grinding brakes and rotors. It is definitley metal to metal rub. I have already checked for tire rub and have nothing there. Has anyone else ever heard of or experienced this type of problem? used
dblmikeusa1 is offline
post #2 of 12 (permalink) Old 11-06-2004, 08:33 PM
TMac325is's Avatar
power steering fluid?
TMac325is is offline
post #3 of 12 (permalink) Old 11-06-2004, 08:34 PM Thread Starter
Power steering fluid is full.
post #4 of 12 (permalink) Old 11-06-2004, 09:31 PM
Live Fast. Drive Faster.
buuhh99's Avatar
buuhh99 has a reputation beyond repute buuhh99 has a reputation beyond repute buuhh99 has a reputation beyond repute buuhh99 has a reputation beyond repute buuhh99 has a reputation beyond repute buuhh99 has a reputation beyond repute buuhh99 has a reputation beyond repute buuhh99 has a reputation beyond repute buuhh99 has a reputation beyond repute buuhh99 has a reputation beyond repute buuhh99 has a reputation beyond repute
Send a message via AIM to buuhh99
wheels rubbing have the same probblem rioght now
buuhh99 is offline
post #5 of 12 (permalink) Old 11-06-2004, 09:35 PM Thread Starter
I had 15 inch rims on when I noticed it the first time. I have recently installed 16 inch rims and have the same problem. I will check the rims to see if there are any marks that would show rub. If that is the case, what is it rubbing on?
post #6 of 12 (permalink) Old 11-06-2004, 09:43 PM
Been here a while.
97alpineM3's Avatar
97alpineM3 is a name known to all 97alpineM3 is a name known to all 97alpineM3 is a name known to all 97alpineM3 is a name known to all 97alpineM3 is a name known to all 97alpineM3 is a name known to all
What width tyres are you using???... if they are rather wide.. then I could see why your getting a scraping noise when turning.. it happens... besides that.. did you fill your own Power steering fluid???
If so.. did you use power steering fluid.. because most of these systems dont take regular power steering fluid...
Good Luck,
Les
1997 E36 M3 1990 E30 325i
97alpineM3 is offline
post #7 of 12 (permalink) Old 11-06-2004, 09:49 PM Thread Starter
For the tires I am using 225-50-16 on a 7.5" wide rim. As far as the power steering fluid, I have not touched since I bought the car 2 1/2 months ago. Perhaps I should draw some fluid and check the color. Is there a specific brand that I should use?
post #8 of 12 (permalink) Old 11-06-2004, 09:55 PM
Been here a while.
97alpineM3's Avatar
Tires size should be fine when turning... I'd get someone to turn the wheel while you stick your head around there and see if you can find what is making that noise...
As for the fluid... most BMW power steering systems use ATF fluid.... not power steering fluid... so just check the level.. if your loosing fluid... fill it up.. if you keep loosing fluid... then check the outside of the container.. if it looks like fluid is on the top.. but your sure your cap isnt loose.. that means you have regular power steering fluid.. due to that fact that it is boiling over... ATF fluid has a higher boiling point than power steering fluid... thus why they use it.. due to the progressive steering rack.
Good Luck,
Les
post #9 of 12 (permalink) Old 11-07-2004, 03:34 AM Thread Starter
Looks like I have my day planned for Sunday! Thanks for the info, I will update when I determine what is the cause.
post #10 of 12 (permalink) Old 11-07-2004, 11:02 AM
BUSTaMOVE is an unknown quantity at this point
its actually the rotors edge has worn through the break pad and is now making that sound , had same thing with my car and fixed it with ne pads and saw a huge run though the pad on one side where the sound was coming from
BUSTaMOVE is offline
post #11 of 12 (permalink) Old 11-08-2004, 10:44 AM
buuhh99's Avatar
my back right rubs
buuhh99 is offline
post #12 of 12 (permalink) Old 11-09-2004, 12:23 AM Thread Starter
I never got a chance to look Sunday, but thanks for giving some extra areas to pay attention to.
Steering wheel noise on 325xi on right turn rms 3-Series (E46, E90) 1 10-11-2005 12:19 AM
Popping Noise When I Turn Wheel Or Go Over Bumps BMW-ATI 3-Series (E36) 7 07-06-2005 01:43 PM
Odd Noise? Won't turn over? kraze0g 3-Series (E36) 4 08-12-2004 01:47 PM
1999 328i Rubbing metal engine noise yogi799 3-Series (E46, E90) 7 08-23-2003 06:01 PM
