main beam not working - BMW Forum - BimmerWerkz.com
Old 02-24-2009, 05:00 PM   #1 (permalink)
jcscholzi is on a distinguished road
i have a '95 323i coupe. the other night my main beam failed and i had to drive home on the fog & side lights, full beam still works when i pull stalk towards me but it will not put on high beam as i have no main beam. buls look fine, checked fuses and relay. the relay was hot but could not see anything else. any clues
Thanks
John
jcscholzi is offline   Reply With Quote
Old 02-24-2009, 05:16 PM   #2 (permalink)
jmo69's Avatar
Car: 1998 328is 2003 325xi
jmo69 is on a distinguished road
Check for power at the bulbs first and work your way back to the switch. Possibly the dimmer switch? Just my $.02
Cosmos schwartz metalic Sparco strut brace factory X-brace 55w 6000k HID w/LED angel eyes smoked Lamin-X blacked out sidemarkers,tails and brakelights. DDM smoked corners and pedals. 35% tint all around, Prosport water temp and oil pressure gauges, Home Depot lip, M3 rear diffuser ASC-T delete.
jmo69 is offline   Reply With Quote
Old 02-24-2009, 06:22 PM   #3 (permalink)
vincentmb615's Avatar
Car: 94 325i two toned full body kit
vincentmb615 is on a distinguished road
Send a message via AIM to vincentmb615
low beam failure? dont ever really recall a relay being hot in my life check your bulbs agian i lost my low beams and my highs worked fine swap that relay with a known working one i thought there was one for each side i had a intermit failure with a low beam and it was the connection
[94 325i two toned
vincentmb615 is offline   Reply With Quote
Main Beam problem Geordiedownsouth 5-Series (E12,E28, E34, E39, E60) 7 07-02-2007 05:15 AM
Main light switch michael_99 3-Series (E21, E30) 4 01-25-2007 11:27 PM
Need to main my rims Q_BMW 3-Series (E36) 2 08-26-2004 10:34 AM
Main Key CS1 3-Series (E36) 1 05-24-2004 11:01 AM
What are the main symptoms of a ... KingScare 3-Series (E36) 6 01-30-2004 07:26 AM
