I am seriouslly considering a S52 swap. However, I want to do an OBDI conversion at the same time to unleash a few more horses. I am curious about a couple things involving the engine management system.
1) Will my current ECU be able to work with the S52, I have a 1995 325i.
2) If I need to upgrade my ECU, what ECU do I need?
3) Would It be worth getting a Standalone like an AEM or MOTEC system(I dont like this idea because it means serious $$$$)
4) I am guessing to convert to the MAP system I would need a Stand-Alone system, because I am guessing the s52 obd II system was bases of a MAF sensor.
Thanks
well heres wat i know...
1) ur ECU wont work
2) probably stand alone is ur best bet, or the ECU from the same motor should work i think....
3)Yes, standalone would definately be worth it, hit up Jason (triggerhappi) he knows a great system
4) not really a question and i dont really understand, both obd1 and 2 have MAF sensors
Thanks
1. No. When you get the motor make sure to pick up the ECU and electronics associated with it all.
2. The ECU that comes with that motor.
3. Not for N/A in my opinion. Most standaloens are pretty expensive and im pretty sure you're not going ot learn how to tune something like a megasquirt. make everything work well by getting the ECU with the motor.
4. Dont go standalone and you wont hav a problem.
I recommend you just do the s52 swap. Theres a lot more to an OBDI swap than you think. Do the s52 swap and do the m50 intake manifold conversion.
drz, both MAF's are 3".
