MAF disconnected causes HARD shifting (auto) - BMW Forum - BimmerWerkz.com
post #1 of 8 (permalink) Old 08-22-2014, 03:08 PM Thread Starter
Quoted: 1 Post(s)
George Delves is on a distinguished road
Hello All!
I've got a '97 328i convertible.
I had a bad MAF where the car would hardly idle with the MAF connected, but would idle fairly well with it disconnected. However, if I tried to drive it with the MAF disconnected, the auto trans would shift with a real hard clunk at each gear.
I cleaned the MAF to no avail so I ordered an aftermarket MAF and installed it.
The car ran great again, shifted real smooth when I took it around the block. When I came back to it that afternoon, it was difficult starting and the "sproket" light was on on the dash (as it had been with no MAF.)
I cleaned the connector plug to the MAF, plugged it in and viola, it worked again! So I took it for a drive and about four miles into it the "sprocket" light came back on and the rough shifting returned.
Now, cleaning the connector has no affect and I wonder it it was just coincidence that it seemed to work before.
Any ideas?
George Delves is offline
post #2 of 8 (permalink) Old 08-22-2014, 04:35 PM Thread Starter
Quoted: 1 Post(s)
These are the OBDII codes it's throwing:
P1250 -- unknown
P0170
P0173 -- upstream O2 sensors
P0740 -- torque converter clutch circuit open.
also
P1188 - fuel control, bank 1, sensor 1
P1189 - fuel control, bank 2, sensor 1
P0442 -- evap. sys. small leak detected, faulty purge solenoid, fuel vent solenoid, loose or faulty purge line or fuel cap.
The torque converter clutch solenoid worked when the MAF was first replaced, didn't work with old MAF disconnected and doesn't work at all now.
I am assuming there is a chain of symptoms springing from just one or two causes.
post #3 of 8 (permalink) Old 09-01-2014, 03:50 AM
Bonginkosi is on a distinguished road
Question mr
Hi I have a BMW e46 318i 1999 model automatic and the air flow is disconected but the car work and has power but it shows a telle light comes on next to the D sign when driving but when we connect the air flow the light does not appear but the car does not have the power any more. Please tell me what to do and how this is bad as I use it when disconected is it put the engine to denger. Or do I need a new air flow.
Bonginkosi is offline
post #4 of 8 (permalink) Old 09-01-2014, 03:56 AM
Question mr Bonginkosi
post #5 of 8 (permalink) Old 09-01-2014, 06:34 PM
David Mc's Avatar
Quoted: 8 Post(s)
David Mc is on a distinguished road
P1250 -- unknown
P0170
also
Check all fuses and hoses for a vacuum leak. Strictly speaking, when the MAF is replaced, adaptation values should also be cleared (as the DME will have attempted to compensate for faults by adjusting the air/fuel mixture). Your car will eventually re-learn the correct values and compensate accordingly, but clearing the adaptation values makes this process a little easier by reverting the values to factory default settings. When checking for vacuum leaks, check the intake boot as often cracks will appear underneath and are not immediately apparent.
David Mc is offline
post #6 of 8 (permalink) Old 09-02-2014, 12:04 PM Thread Starter
Quoted: 1 Post(s)
Thank you David.
I am planning to replace all of the intake-associated vacuum hoses as they are all looking pretty sorry and this would be simpler than chasing what could be multiple vacuum leaks.
The intake boot, however, looks like it may have been replaced in the not to distant past, but I will inspect it carefully when I have if off.
Meanwhile, is there a listing somewhere of the sizes of all of these different hoses such as the CCV, ICV and Fuel Tank Breather Valve, etc.?
I would like to purchase enough of the proper sizes of hose before disassembling the intake components if possible.
Thanks again!
post #7 of 8 (permalink) Old 09-03-2014, 07:01 AM
David Mc's Avatar
Quoted: 8 Post(s)
George, input your VIN number into RealOEM.com for exploded parts diagrams and original part numbers. I source the bulk of my parts from Pelican Parts and Schmeidmann.
David Mc is offline
post #8 of 8 (permalink) Old 09-03-2014, 09:15 AM Thread Starter
Quoted: 1 Post(s)
Thanks David.
HELP please: 1998 BMW 323is hard shifting up and down at around 15-20 mph AaronSM 3-Series (E36) 2 02-07-2010 12:29 PM
hard shifting jfertita 3-Series (E21, E30) 14 10-29-2006 07:45 PM
Shifting Kinda Hard whitey_E30 3-Series (E21, E30) 1 08-21-2005 07:45 PM
Shifting Into Reverse Hard 2000BMW323i 3-Series (E46, E90) 6 03-08-2005 08:05 PM
Shifting My Auto Slvr e39 5-Series (E12,E28, E34, E39, E60) 7 10-01-2004 04:32 AM
