M50B25 idle problem - BMW Forum - BimmerWerkz.com
Old 11-13-2012, 12:32 AM   #1 (permalink)
Krotes is on a distinguished road
M50B25 idle problem
I've had this problem since I bought the car. When I start the car cold it runs idle pretty well and stable and doesn't smoke, but after few minutes rpm goes down a bit and it starts running so bad that the whole car is shaking and it's smoking quite a lot too...so it seems to start running on rich for some reason? So far I've changed new bosch lambda, new sparkplugs, new camshaft position sensor, checked all intake hoses for any cracks and leaks, cleaned icv and tested that it's working and also tested ignition. Still no any diffirence. Got any ideas what to do next?
Krotes is offline   Reply With Quote
Old 11-15-2012, 10:55 PM   #2 (permalink)
Car: 94 325IS
ElTonyo69 is on a distinguished road
I had a very rich and rough idle ad my problem ended up being the VANOS not being adjusted correctly.
ElTonyo69 is offline   Reply With Quote
Old 11-16-2012, 01:38 PM   #3 (permalink)
I got non-vanos, so can't be that.
Old 11-18-2012, 07:26 PM   #4 (permalink)
Ivan413's Avatar
Car: 95 BMW 318i
Ivan413 is on a distinguished road
My e36 had an idle problem. If you haven't cleaned your MAF sensor, so and if problem continues its most likely you o2 sensor causing the problem
Just your avg 17 year old with an e36 318i as a DD!
Ivan413 is offline   Reply With Quote
Old 11-23-2012, 08:18 PM   #5 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
Bingo. This is most likley the problem. A bad O2 sensor can cause a host of issues as the car doesnt know what the air fuel mixture is and cant adjust properly. Bad idling and running rich is quite common.
Click HERE to see my E36 Blog
BMW e36 m50b25 with 6speed m3 gearbox. auuu 3-Series (E36) 0 01-04-2010 09:18 PM
M50B25 from e34 to e30 problem Toninho 3-Series (E21, E30) 1 07-30-2007 12:43 PM
M50B25 from e34 to e30 problem Toninho 5-Series (E12,E28, E34, E39, E60) 0 07-19-2007 02:57 AM
Technical data of m50b25 nukeduster 3-Series (E36) 2 01-28-2007 10:58 PM
M50B25 (no vanos) conversion to 3.0? enemigo 3-Series (E36) 8 05-21-2004 12:48 AM
