m50 engine - BMW Forum - BimmerWerkz.com
Old 02-21-2004, 01:32 PM   #1 (permalink)
racebait is an unknown quantity at this point
Hey guys,
Alright guys, i'm a newby to the whole bimmer thing. coming from a 12 second transam and looking for a little more refinement (and gas mileage). so help me out here. i have not yet baught my bmw i am currently doing my research as to which model to buy. i'm curently considering the 1995 m3 or 325 i'm planning on doing some serious parts swapping/ modification. ie cams, porting, stage 2/1 turbo kit from AA.
any how onto the question. i'm not a wealthy man and i was considering the 1992-98 models, which one is the best consideration. also i've seen referances to the m50 engine being a better motor. which motors are the best engineered for boosted aplications.
i appologise if the questions are really uneducated ones, but asking is the only way i can become educated.
Thanks Guys and Gals
Bill
racebait is offline   Reply With Quote
Old 02-23-2004, 03:41 PM   #2 (permalink)
i've also seen referance to the r35 which is the motor in the newer bimmer M3 any info on these... does anyone know of a site that will have the different engine codes and specs.
Thanks
Old 02-23-2004, 04:00 PM   #3 (permalink)
hodges76 is an unknown quantity at this point
Send a message via Yahoo to hodges76
1.2: BMW Motors
1.2.1: Overview
(by Rick Kjeldsen)
BMW's middle name is "motor", and the quality of their engines lives
up to it. Long lived, they are just getting broken in around 30k
miles, and with care easily last 200k and more. They are overdesigned
enough to take major HP modifications in stride. The performance versions,
as in the M cars, produce as much or more HP/Liter as any contemporary
(normally aspirated) production engine. They run smooth, eagerly pull
to redline and can run hard at redline all day without missing a beat.
Combine all that with a clean design which makes them a joy to work on.
The early cars (2002, early 3 series, etc) were powered by variations
on a well designed 4 cylinder block. This same basic engine has been
in use for over 25 years, and forms the basis of the very successful
E30 M3 race engines. Rumor has it that blocks for 1000+ HP Formula 1
race cars were simply selected off the manufacturing lines.
Later BMW added a large (3+ liter) in-line 6 for it's larger cars
and a small (~2.5 liter) 6 to improve the performance of it's smaller
cars. Each of these has gone through several variations over the years.
More recently BMW has built several new engines, including a V12 for
it's largest cars, V8s in a couple of sizes and a new aluminium block
2.8 liter in-line 6.
The M engines started with a major modification of the big 6 block
for the M1. It included several elements tuned for racing, including
o-rings instead of gaskets, one throttle per cylinder, etc. Later
the same technology was applied to the 4 cylinder block with a
4 valve/cylinder head to produce the E30 M3 engine.
(by bthongsa@ux4.cso.uiuc.edu)
The small-6 SOHC engine is designated the M20 series. This motor started
out in 1978 with the E21 320/6 and 323i models. As the names suggest,
the 320/6 was a 2-liter with a 4-barrel carb, and the 323i was a
2.3 liter with K-Jetronic injection.
The ETA engine, at 2.7 liters, is basically a bored and stroked version
of the 2.3 liter with Motronics, a special economy camshaft, lighter
valve springs, and a special long and small diameter runner intake
manifold. The head was basically the same as the 2.3 otherwise, with
smaller valves and ports.
The E30 325i motor is another derivation of this series of motors.
For this one, BMW shortened the stroke of the ETA engine, and used
a cylinder head with bigger ports and valves, along with a more
radical cam and stiffer valve springs (over the ETA). A larger throttle
body was also included in the package with the 323i style manifold.
The M50 engine (92-on 325i, 525i) is pretty much more or less a new
design. It is, however, based on the M20 engines.
The E30 M3 engine used the same basic block as the '84-'85 318i, and
all the other M10 4-cylinders that came before it. ('63 1500 through
the 2002 through the 320i through the early 318i) The single cam
version had a 23+ year run. The M3 version has siamesed cylinders
and a longer stroke crank, along with the 16-valve head.
The M40 engines found in the '91-on 318i's are not related to the
earlier motors in anyway.
Hope this helps,
Matt
<img src='http://selectmotors.net/images/pass/bmwi.jpg' border='0' alt='user posted image' />
'93 325I
94k miles
F/S 6000 obo
Only mods:
Conforti chip
hodges76 is offline   Reply With Quote
Old 02-24-2004, 12:12 PM   #4 (permalink)
Matt
thanks a bunch that's exactly the info i was looking for.
Thanks
Bill
Help...92 318I Gas Engine Sounds Like a Diesel ? DougJP 3-Series (E36) 13 04-10-2006 11:56 PM
Bad Engine Idle And Fault Not Found.. Paraklas 3-Series (E21, E30) 10 06-16-2005 09:25 PM
