M40 Fault Codes. - BMW Forum - BimmerWerkz.com
post #1 of 4 (permalink) Old 02-13-2005, 08:19 AM Thread Starter
SBSD's Avatar
SBSD is an unknown quantity at this point
As per my other thread (engine judder), i've cleaned out the ICV which hasn't solved the problem, and my next suspicion is the o2 sensor.
I found THIS on the net about how to pull engine codes with the footpedal depression, i've also heard that the timing for this proceedure is vital and i don't seem to be getting any flash codes at all, meaning either theres no fault to display, or i'm just doing something wrong used
Any ideas or tips for getting the fault codes up?
Cheers
<a href='http://us.f3.yahoofs.com/users/42a3b727zebf48ce8/6492/__sr_/9098.jpg?phVv7oCB.2P7MzGW' target='_blank'>http://us.f3.yahoofs.com/users/42a3b727zeb...hVv7oCB.2P7MzGW</a>
SBSD is offline
post #2 of 4 (permalink) Old 02-13-2005, 01:36 PM
Iíve just read the link and I donít believe it Iíve work for BMW as a tech for 20years and Iíve never heard of this before.
P.S.
If you make it work let me know please
bad man working is offline
post #3 of 4 (permalink) Old 02-13-2005, 01:40 PM
Sorry should have added if your engine rough at idle my best guess is air leaks on the intake system. Blank-off the air filter end of the air flow meter with the engine running and see if it stops if it doesnít listen for the air being drawn in.
post #4 of 4 (permalink) Old 02-13-2005, 01:51 PM Thread Starter
SBSD's Avatar
[snapback]291098[/snapback]
Surely though that would effect the idle from cold as well?
If you read my other thread, the problem manifests when the engine warms up, from cold it ticks like a swiss watch, its only occuring with a bit of engine temp whilst i'm pulled up at lights/junctions...
unless you've any other ideas i'm going to get it plugged in and check for fault codes with a specialist next week, see if the o2 (lambda) sensor is at fault, if not, i'm drawn back to the idle control valve I think.
(p.s; i've given up trying for fault codes off the accelarator pedal, just can't seem to get it to work at all)
Cheers.
SBSD is offline
Obd1 Fault Codes, Help! toast_mcmann 3-Series (E36) 10 08-01-2005 10:08 PM
Fault Codes. WarNox 3-Series (E36) 5 06-12-2005 05:59 PM
M3 Fault Codes? beemernubee M-Series (M1, M3, M5, M6) 2 04-06-2005 12:49 AM
1998 M3 Fault Codes beemernubee 3-Series (E36) 1 03-27-2005 01:26 PM
