M3 Charging Problems - BMW Forum - BimmerWerkz.com
Old 03-19-2009, 04:08 PM   #1 (permalink)
led
led is on a distinguished road
My 99 M3 is not charging correctly. When I check the voltage at the battery in the trunk, with it running, I get 12.0-12.5. When I check it under the hood I get around 14.0, I also get around 14 at the lighter. Battery holds a charge for 3-4 days with regular use then i have to put the charger to it. Why would it be so much less back at he trunk
led is offline   Reply With Quote
Old 03-20-2009, 03:42 PM   #2 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
Because it loses current along the cables to the engine , apart from that I would deffo say its your alternator.
Old 03-20-2009, 06:24 PM   #3 (permalink)
Sodium Chloride
saltshaker185's Avatar
Car: 95 M3
check what kind of voltage you are getting off your alternator. sounds like its not doing its job of keeping the battery charged for you.
Old 03-20-2009, 06:46 PM   #4 (permalink)
led
Found it, bad connector on one of the wires that connects to the block under the where you can jump start from. Connectors appeared ok but when you moved it the voltage back at the battery went up to 13.7. thanks for the input
Charging Problem tAgC 5-Series (E12,E28, E34, E39, E60) 10 06-27-2008 02:27 PM
735il not charging need help revharde30 1,6,7,8 - Series and Mini Cooper 7 03-19-2008 05:16 PM
Charging Problem Help Breaker2944 3-Series (E36) 6 02-10-2006 11:12 PM
Battery Not Charging woode12 3-Series (E21, E30) 3 12-19-2004 08:34 PM
318i-Not charging Hypnogaja 3-Series (E21, E30) 15 10-27-2004 03:18 PM
