A/m Switch - What Exactly Does It Do? - BMW Forum - BimmerWerkz.com
Old 12-09-2004, 01:28 PM   #1 (permalink)
streetdreams is an unknown quantity at this point
Yeah I tried to search but I dont know what its called so I just got random posts.
What does the thing left of the shifter that says A/M do? Is thats so I can shift the car myself? If so how? Or is it like a sport shift button? The car is an Automatic 92 325i. Thanks for the help.
streetdreams is offline   Reply With Quote
Old 12-09-2004, 02:21 PM   #2 (permalink)
skawful's Avatar
skawful is an unknown quantity at this point
Send a message via AIM to skawful
A Stands for Automatic. In this mode the car will shift gears for you unless you pull the selector to a certain gear. In that case it will select between that gear or lower: so if you are in "A" mode with the selector on 2 the transmission will chose between gears 1 or 2. BUT if it is in "A" mode and in gear 3 your car will shift faster (between gears - even faster than M)
M Stands for Manual. In this mode the car only shifts gear when you move the selector. BUT (at least in my '93 325i) it won't shift into 4th (out of 4 gears in our auto trannies). But this can be usefull when you want to cruise in a gear and not shift... or whatever...
Personally I just use 3 and its the best of all worlds... But in the mornings I use A and during some sort of fun-ish driving I use M.
Have fun: and also, M will not overide your computer to over-rev the engine, which means you can't fuck up your engine with M mode.
<img src='http://img259.imageshack.us/my.php?image=sig8hw.jpg' border='0' alt='user posted image' />
skawful is offline   Reply With Quote
Old 12-09-2004, 03:21 PM   #3 (permalink)
locutuz is an unknown quantity at this point
The only noteable use for M is in snowy conditions... the car will start in 1st normally and in snow or ice that means even a little throttle will send your tires into a nice slick spin..
drop it in manual, and select 2nd or 3rd gear instead... much smoother start on slick surface..
i've never even tried it honestly.. i like to spin.. but i've read that's what it's useful for.
Nate ('95 M3) - Grants Pass, OR
locutuz is offline   Reply With Quote
Old 12-09-2004, 05:00 PM   #4 (permalink)
Threadkiller
bitcore's Avatar
use the search button on the forums.
Old 12-09-2004, 05:52 PM   #5 (permalink)
[snapback]246663[/snapback]
Did you read the very first sentance in my post?
Old 12-09-2004, 05:55 PM   #6 (permalink)
[snapback]246612[/snapback]
Ok thanks. So if it never snows where Im at I just should not use it. I can shift the car fine with the car in auto or manual mode, so I guess the button is pointless for me. Thanks guys.
Old 12-09-2004, 06:08 PM   #7 (permalink)
if you get an M3 you get a 3rd option.. A, S, and M. S is fun. =)
Old 12-09-2004, 07:03 PM   #8 (permalink)
[snapback]246713[/snapback]
I will ever own another auto BMW again.
DIY Push Start Ignition El Presidente 3-Series (E36) 161 03-04-2011 03:13 PM
E34 Clutch Switch -- HELP ! ! ! m3driver97 5-Series (E12,E28, E34, E39, E60) 5 10-28-2005 05:22 PM
Changing The Light Bulb In Headlight Switch ben_t 5-Series (E12,E28, E34, E39, E60) 2 06-09-2005 08:21 AM
Wiper Switch dsstultz 3-Series (E21, E30) 1 02-17-2005 09:45 PM
Instrument panel switch jackinsac 3-Series (E21, E30) 4 03-16-2004 05:27 PM
