Lower control arm rear rubber bushings - BMW Forum - BimmerWerkz.com
post #1 of 10 (permalink) Old 01-11-2009, 07:05 PM Thread Starter
cjscopp's Avatar
cjscopp is on a distinguished road
Our 1995 325i appears to need the rubber rear bushings on the front lower control arms. They are split and when you torque the tires they move back and forth. They look rather flimsy and weak. Anyone replace them and how did it go?
cjscopp is offline
post #2 of 10 (permalink) Old 01-11-2009, 07:12 PM
Ich bin der Modifikator
johnnyBgood's Avatar
johnnyBgood is a jewel in the rough johnnyBgood is a jewel in the rough johnnyBgood is a jewel in the rough
Are you talking about RTAB's........rear trailing arm bushings, I replaced them about a year & 1/2 ago.....its about a 2 1/2 hour job.....check link below:
United Bimmer - BMW Enthusiast Community and Forums : Bimmer Technical Help
____________________________________________
johnnyBgood is offline
post #3 of 10 (permalink) Old 01-11-2009, 07:53 PM
my car is red
94BMW325i's Avatar
94BMW325i has much to be proud of 94BMW325i has much to be proud of 94BMW325i has much to be proud of 94BMW325i has much to be proud of 94BMW325i has much to be proud of 94BMW325i has much to be proud of 94BMW325i has much to be proud of 94BMW325i has much to be proud of 94BMW325i has much to be proud of 94BMW325i has much to be proud of
Yes. I put on the e30 m3/e36 95 m3 offset control arm bushings on my car. I had access to a press so it made the job a lot easier. A few websites have DIY's on the job. I would check out the one on understeer.com
94BMW325i is offline
post #4 of 10 (permalink) Old 01-12-2009, 10:23 AM Thread Starter
cjscopp's Avatar
No, I am referring to the front suspension. On the back of the lower control arm there is a rubber mount that bolts to the undercarriage. I found them on line and they go fro about $25 each but I think I will have to press them in. I was just wondering if anyone had done this. Here is a pic of the lower control arm and the bushing I am talking about is at the rear and labeled #4
cjscopp is offline
post #5 of 10 (permalink) Old 01-12-2009, 10:38 AM
Quoted: 1 Post(s)
Bushings
We carry a lot of bushings and control arms that may be helpful for you. I believe this may be an example of what you need. BMW Control Arm Polyurethane Bushing Kit
-Max
FCP Groton
877-634-0063 |
- European Car Parts Specialists
- Import Replacement Car Parts
FCPGroton is offline
post #6 of 10 (permalink) Old 01-12-2009, 01:47 PM Thread Starter
cjscopp's Avatar
Now THAT looks like the way to go. The original rubber ones look very suspect and they obviously don't last long. Your new design looks like it would perform better and last longer. Do they simply "pop" into the popsicle housing that bolts to the undercarriage? The original ones press in and out as the bushing has a metal outer housing. From the picture of your bushing it appears to just have a big lip at the edges that must spring out over the edge of the housing
cjscopp is offline
post #7 of 10 (permalink) Old 01-12-2009, 02:05 PM
Quoted: 1 Post(s)
Bushings
Yes it is lipped just like you stated. If you ever have any questions too you can give our customer service a call, we also have a certified tech on call to answer any parts questions. 877-634-0063
thanks.
FCP Groton
877-634-0063 |
post #8 of 10 (permalink) Old 01-13-2009, 09:24 AM Thread Starter
cjscopp's Avatar
Picked up a set of Powerflex bushings and installed them last night. The old ones had broken apart and were banging around in the "popsicle" mount. Pretty easy job and a huge difference in ride quality. The banging while going over bumps is gone and the front end is much more stable. $68 bucks OTD and worth every penny.
cjscopp is offline
post #9 of 10 (permalink) Old 01-16-2009, 10:06 AM
Quoted: 1 Post(s)
Bushings
Good to hear you solved the problem! Best of luck with everything!!!!
-Max
FCP Groton
877-634-0063 |
post #10 of 10 (permalink) Old 02-17-2009, 11:32 PM
jmo69's Avatar
jmo69 is on a distinguished road
-Max
I bought these and were a snap to install. Used the understeer diy and a homemade press (my vise would have worked too). Lollipops went back on by hand.
Cosmos schwartz metalic Sparco strut brace factory X-brace 55w 6000k HID w/LED angel eyes smoked Lamin-X blacked out sidemarkers,tails and brakelights. DDM smoked corners and pedals. 35% tint all around, Prosport water temp and oil pressure gauges, Home Depot lip, M3 rear diffuser ASC-T delete.
jmo69 is offline
fs: e39 rear headrest, rubber floor mats and rear arm rest kman OEM Parts 2 01-07-2008 11:30 PM
Rear Control Arm Bushings??? Skatebline 3-Series (E21, E30) 9 05-27-2006 02:40 AM
Wishbone/rear Lower Control Arm doughnutboy 3-Series (E36) 3 08-21-2005 11:02 PM
Control Arm Bushings theruss1an1 3-Series (E36) 2 10-16-2004 01:30 AM
Aftermarket Rear Lower Control Arm Yimzoo M-Series (M1, M3, M5, M6) 0 10-21-2003 10:41 PM
