Low Idle Ticking - BMW Forum - BimmerWerkz.com
Old 11-19-2004, 05:52 PM   #1 (permalink)
locutuz is an unknown quantity at this point
Well I've searched and there's been plenty of topic about clicking engines at higher rpms.. but the issue I am having is very specific.. I used to own an acura integra and it endedup with a slightly bent valve, and so evermore it had a ticking coming from the engine.
I am getting this precise sound from my '95 M3, but only when it's idling. My car idles around 800rpm and normally after it idles for about 2-3 minutes it begins ticking. A gentle rev will make the ticking go faster, so it's definitly engine related. A rev to about 3k stops the ticking, but it will usually pick back up after about 30 seconds.
My thoughs on this issue is that it's an oil problem.. the engine rev kicks up the oil and the car is fine until it drains back down, wheras it starts ticking again.
Anyone had this same issue?
- Nate
Nate ('95 M3) - Grants Pass, OR
locutuz is offline   Reply With Quote
Old 11-19-2004, 05:56 PM   #2 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Try adding another quart or a half a quart ... sound should dampen...
Good Luck,
Les
1997 E36 M3 1990 E30 325i
Old 11-19-2004, 06:08 PM   #3 (permalink)
I've tried that, even tried a Quart of slick50, no dice. =(
- Nate
Old 11-19-2004, 07:54 PM   #4 (permalink)
Retired administrator
triggrhaapi's Avatar
ticking could be a VANOS unit on it's way out. No way to be sure unless you take it to a mechanic to be inspected.
Addicted to Speed Since 1997
Old 11-20-2004, 03:04 PM   #5 (permalink)
supark is an unknown quantity at this point
valve lifters?
supark is offline   Reply With Quote
Old 11-20-2004, 03:25 PM   #6 (permalink)
I don't know enough about the vanos to really be of any help. It does sound like it could be a lifter related issue. It's generally the most common engine component to make a clicking noise. If you have more than a 100K miles you could try having the lifters adjusted and the clearance checked.
Old 11-20-2004, 09:03 PM   #7 (permalink)
Yup, almost 120k miles... sounds like a good starting point.. thank you all for your suggestions!
- Nate
Idle Problems BeelZibub 5-Series (E12,E28, E34, E39, E60) 10 07-10-2005 04:56 AM
Bad Engine Idle And Fault Not Found.. Paraklas 3-Series (E21, E30) 10 06-16-2005 09:25 PM
Warmed up idle puzzle. nightsurfride 3-Series (E21, E30) 2 02-03-2004 08:04 PM
