low beam failure????? - BMW Forum - BimmerWerkz.com
Old 09-06-2007, 12:46 AM   #1 (permalink)
matt325is's Avatar
matt325is is an unknown quantity at this point
okay so i have a 325is and after I run my gears high (say around 5-6000 Rpm's) After slowing down a bit my OBC reads "Low Beam Failure" however it has nothing to do with the headlights...I have no clue what low beam is thou...can u guys help me out??thnx!
matt325is is offline   Reply With Quote
Old 09-06-2007, 10:09 AM   #2 (permalink)
drz
master of his domain
drz's Avatar
Car: zhp
"Low Beam Failure" usually indicates that one of your low bean headlight bulbs is out. If your headlights are working fine, I wouldn't worry about it. These cars are old and get confused often. Mine keeps telling me my brake lights are out.
It is usually caused by the presence of moisture or corrosion at the connection terminals. You may want to check those and clean them up. Also see if the wires seems frayed or if any connection seems like it is not as sturdy as it should be.
Turkey Fleet Bond Holder
Low Beam Check Relay Bear 3-Series (E21, E30) 2 08-18-2007 10:22 AM
Headlight problem: City lights don't work (low and high beam do) KILOCHARLIE 3-Series (E36) 4 09-21-2005 01:33 AM
Best Kind Of Headlight Bulb? all4isu 5-Series (E12,E28, E34, E39, E60) 6 10-18-2004 02:26 PM
Low Beam Failure MyCrowsSoft 3-Series (E36) 6 02-03-2004 02:06 AM
Fog Light Modification E39 ViewMaster Bimmer Talk/Motorsports Talk 1 10-25-2003 11:09 PM
