» Sponsors
» Sponsors
Old 07-02-2009, 10:54 AM   #1 (permalink)
325isBMW1988's Avatar
Car: 1998 328i
Photos: 10
325isBMW1988 is on a distinguished road
Send a message via AIM to 325isBMW1988
Exclamation Lots of heat underneath driver side!!!
First off I just bought a 1998 328i.
After driving for a good 20 minutes I will start to feel tons of heat coming from underneath by dash on the driver's side. Right now my a/c wont work and when I put on just regular air it fluctuates from fast to slow.
I dont know if my air and a/c problem is causing the heat coming from my driver's side or not but if you guys could help me out i would greatly appreciate it! The heat gets so bad sometimes that it makes me sweat
325isBMW1988 is offline   Reply With Quote
Old 07-02-2009, 11:01 AM   #2 (permalink)
Photos: 0
jmana is on a distinguished road
That's strange, because I just bought a 98 328i, and I looked through the service records and one of the things the car was taken to the dealer for was excessive heat blowing from under the dash! The dealer couldn't pinpoint the problem, and I don't notice it, so apparently the problem went away on it's own Maybe you will be so lucky!
jmana is offline   Reply With Quote
Old 07-02-2009, 06:02 PM   #3 (permalink)
Car: 1998 328i
Photos: 10
hopefully it does! was your 328i sitting for a long time before you purchase it?
Old 07-02-2009, 09:49 PM   #4 (permalink)
Photos: 0
I think it was sitting for a while, I think the owner was afraid to drive it and have something else break!
Old 07-03-2009, 08:42 AM   #5 (permalink)
Car: 1998 328i
Photos: 10
lol, hopefully it just goes away because its not hindering my car's performance at all
Old 07-03-2009, 08:46 AM   #6 (permalink)
Car: 530i-2002 & E280-2007
Photos: 1
rashid is on a distinguished road
I would say the engine heat is coming into the cab. I dont think such problem can go away by its own without fixing. Also can not imagine a dealer failing to identify source of heat inside the cab.
anyway, keep up updated on the progress
rashid is offline   Reply With Quote
Old 07-03-2009, 10:28 AM   #7 (permalink)
Photos: 0
Kraft_E90_werK is on a distinguished road
I have an 09 335i and i feel the heat too....strange...
2009 BMW 335i
Kraft_E90_werK is offline   Reply With Quote
Old 07-04-2009, 05:23 AM   #8 (permalink)
Car: 1998 328i
Photos: 10
Engine heat def. makes sense but how come its only on the drivers side?
Old 07-05-2009, 02:03 PM   #9 (permalink)
Photos: 1
I think due to th position of the steering wheel ... we need one expert to judge ..
Old 07-05-2009, 04:43 PM   #10 (permalink)
The Stig
SHAHAB323IS's Avatar
Car: 2009 Civic Si, 1990 Miata
Photos: 0
could be a stuck open heater valve, is the top dial turned to full hot by chance?
2009 Honda Civic Si
1990 Mazda Miata
Old 07-06-2009, 08:56 AM   #11 (permalink)
Car: 1998 328i
Photos: 10
i have the digital climate control system and both are set to the lowest, 60 F.
i do get some fog (heater core maybe) when using heat or a/c and my a/c doesnt function. the air coming out fluctuates from fast to slow also
any suggestions?
Old 07-06-2009, 05:37 PM   #12 (permalink)
The Stig
Photos: 0
any suggestions?
is it doing this on it's own? like with out you hitting any buttons? does the screen go dim?
If the climate control unit is doing anything without you pushing buttons this might help you. I did this fix on my car a couple years ago.
Richard's Web Site
also regardless of what the temperature is set to, the top dial by the top vent will control hotness or coolness of the air. It controls the heater valve.
2009 Honda Civic Si
1990 Mazda Miata
Old 07-07-2009, 09:47 AM   #13 (permalink)
Car: 1998 328i
Photos: 10
the climate control doesnt start by itself or anything like that. the controls seem fine and it shows that it stays at the air speed i put it to but the air comes out of the vents different speeds.
and the top temperature dial is set all the way to cold....maybe i need to check out my heater valve? and where can i find out how to do this?
Old 07-07-2009, 01:53 PM   #14 (permalink)
The Stig
Photos: 0
Pelican Technical Article: BMW Heater Valve Cleaning/Flushing
that link should help you find it.
the heater valve basically diverts coolant to pass through the heater core, the radiant heat from the heater core is what heats the air that flows through the vents. If you're having heat all the time then the valves could be stuck open allowing coolant to flow through heater core no matter what. I forget which hoses are which, maybe real oem has a diagram of it. It's a bitch to remove and or replace, but an easy way to check would be to warm up the car and feel the hoses by the heater valve, one or two should remain cold if there isn't coolant flowing through the heater core, if they're all hot then you know there's coolant flowing through the heater core even with the dial turned to cold. I hope this makes sense.
2009 Honda Civic Si
1990 Mazda Miata
Old 07-08-2009, 08:42 AM   #15 (permalink)
Car: 1998 328i
Photos: 10
that makes perfect sense! thanks for the help ill check that out today. It makes sense that the problem is what you described.
vB code is On
Heat only coming out of drivers side Yankees368 5-Series (E12,E28, E34, E39, E60) 14 12-06-2005 01:12 PM
Need Driver Side Floormat 2MuchTorque 5-Series (E12,E28, E34, E39, E60) 1 03-01-2005 10:37 AM
Driver's side mirror TheHire 5-Series (E12,E28, E34, E39, E60) 2 06-16-2004 12:10 AM
Driver's side mirror TheHire 3-Series (E21, E30) 0 06-15-2004 11:33 PM
NO DRIVER'S SIDE HEAT! PLEASE HELP! dnbmartin 3-Series (E36) 1 01-03-2004 09:03 PM
