losing water - BMW Forum - BimmerWerkz.com
Old 12-13-2009, 07:36 AM   #1 (permalink)
Car: 1997 328i touring
dudehog is on a distinguished road
losing water
i have noticed the level in my expansion tank (when cold) is slowly going down. there are no leaks from what i can see anywhere, no icky badness in the cap or oil, no damp patches inside the car from leaky pipes. the coolant has anti freeze in it so i've looked for crystal of that on the joints/pipes.
the level is going down about a line at a time (look at the tank and you'll know what i mean). i can't think of anything it could be. it doesn't overheat at all. i'm currently keeping an eye on it for the daily level.
any thoughts would be welcomed. john.
dudehog is offline   Reply With Quote
Old 12-13-2009, 07:54 AM   #2 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
Worth checking around the water pump area for any signs of a leak it will more than likely be a brown residue rather than coolant crystals due to a failing bearing in the pump.
Old 12-13-2009, 08:17 AM   #3 (permalink)
yeah. the coolant is new so thats why i was looking for pink crystals. it's got a replacement engine in it now. the other went pop. it's a new rad too. someone said about a leaky head gasket?
Old 12-13-2009, 08:40 AM   #4 (permalink)
marti5's Avatar
If its a leaky head gasket it will get worse and you will have gunk (mayo) on the dipstick and under the oil cap,might be worth getting a coolant dye that shows up under UV, good stuff, helped me find a leak on mine which I would never had found in a hundred years, do a google search to find.
Old 12-13-2009, 08:44 AM   #5 (permalink)
cool. i'll have a look for that. yeah there's no mayo on the stick or under the cap.. i guess i gotta get a uv light too? how much was the dye?
Old 12-13-2009, 09:10 AM   #6 (permalink)
marti5's Avatar
Feser One UV Acid Green coolant for use in your watercooled pc |Specialtech.co.uk
Old 12-13-2009, 09:16 AM   #7 (permalink)
sweet. that's uber cheap too. i'm guessing the uv lamps are available on ebay and such?
Old 12-13-2009, 09:31 AM   #8 (permalink)
marti5's Avatar
I have this one .
http://cgi.ebay.co.uk/INVICTALUX-UV-...item334f82468d
but this ones good as it plugs in the ciggy lighter
http://cgi.ebay.co.uk/LED-WORK-LIGHT...item518edecda1
Old 12-13-2009, 09:45 AM   #9 (permalink)
hey. thanks for all your help. as soon as i find out the problem i'll let you know. thanks again.
Old 12-13-2009, 10:00 AM   #10 (permalink)
CanyonCreekMT's Avatar
Car: 2006 750Li
CanyonCreekMT is on a distinguished road
Coolant expands when it is hot and contract when cold so I would think this is normal unless you are having to add coolant.
CanyonCreekMT is offline   Reply With Quote
Old 12-21-2009, 09:58 AM   #11 (permalink)
dudes i found it!!! ultimate driving machine my ass!!! i thought i'd jet wash the engine bay to get rid of all the silt and grimness from the roads, aaaaaaaaaaaanyway, the next day i noticed the very base of the expansion tank was ever so slighty wet, literally just around the ring of it. pink!!! the colour of my coolant. i followed the path it could take and below it and to the right is a plastic recess with a hole. traces of pink. the coolant had been making it's way in there and dissapearing through the hole and onto what was beneath it and no trace. i've ordered a genuine o-ring seal from bmw to replace it (aftermarket rad) and i hope this solves the problem. will let you all know.
Old 12-21-2009, 10:08 AM   #12 (permalink)
Well I hope that sorts it.
Old 01-04-2010, 05:08 PM   #13 (permalink)
vicfreg is on a distinguished road
Water pump.
You should be hearing more noise from the engine than usual.
vicfreg is offline   Reply With Quote
1999 e46 318 losing water CR+DR-Ltd 3-Series (E46, E90) 19 11-24-2009 08:12 AM
Losing coolant georgianarock 3-Series (E36) 1 04-14-2008 09:59 AM
E38 98 or under water pump for non water cooled alternators brand new AlpineSixAndSeven OEM Parts 0 10-12-2007 03:58 PM
540 - Water Leak - Radiator? Exp Tank? Water Pump? windarra 5-Series (E12,E28, E34, E39, E60) 2 06-09-2006 10:13 PM
Losing Coolant Mavraam 3-Series (E46, E90) 4 01-13-2005 06:16 PM
