Loose Shifting - BMW Forum - BimmerWerkz.com
post #1 of 10 (permalink) Old 04-17-2004, 02:48 PM Thread Starter
CiscoKid's Avatar
I know my car is a little bit older, but the shifting seems to be a little loose. there is now tension when putting it into gears, it kind of just slides in. Is there any way to make shifting feel a little tighter?
CiscoKid is offline
post #2 of 10 (permalink) Old 04-17-2004, 03:36 PM
Defector
El Presidente's Avatar
an ssk would help a lot.
El Presidente is offline
post #3 of 10 (permalink) Old 04-17-2004, 09:17 PM
Kevin325i's Avatar
Sounds like that plastic ball at the base of the shifter is getting worn, go with the short shift kit as presidente said.
Kevin
Kevin (President TBEA)
Kevin325i is offline
post #4 of 10 (permalink) Old 04-18-2004, 01:42 AM
Andrewsd1985's Avatar
Andrewsd1985 is an unknown quantity at this point
Send a message via AIM to Andrewsd1985
A short shift kit will give you all new bushing which will help. You can also do the weighted selector rod which will give you a better feel.
PRESIDENT OF THE OVER 10 YEARS OLD AND UNDER 100K MILES CLUB
1993 325i 5spd
Benfer Performance Intake
M-tech Pedals and Shiftknob
Bavarian Auto Floor Mats
Wheelskin Steering Wheel Cover
Panasonic Head Unit
Euro Projector Lights w/ black Housing
Black Housing Clear Corners
Dinan Chip
MORE TO COME!!
<img src='http://plaza.ufl.edu/dunna/Pictures/banner.jpg' border='0' alt='user posted image' />
Andrewsd1985 is offline
post #5 of 10 (permalink) Old 04-18-2004, 11:12 AM
M3Daemon's Avatar
M3Daemon is an unknown quantity at this point
Those parts are the ones that wear out and make it loose, just get new ones....
Daemon
<img src='
M3Daemon is offline
post #6 of 10 (permalink) Old 04-18-2004, 01:05 PM
The linkage is worn. You can see the parts you needs from the diagram posted above by Daemon.
The parts are relatively cheap from the dealer. However, if you plan to change the linkage yourself it's a lot of work! My shift linkage is sloppy as hell, but I've put off changing it because of the labour involved.
Bry
<a href='
target='_blank'>- VIEW MY MODS AND PICS</a>
<a href='
target='_blank'>- PARTS FOR SALE</a>
&lt;img src=&quot;
Autotechnica is offline
post #7 of 10 (permalink) Old 04-18-2004, 03:15 PM
M3Daemon's Avatar
Bry
Same here... I hope I can tackle that project in the summer
Daemon
<img src='
M3Daemon is offline
post #8 of 10 (permalink) Old 04-18-2004, 03:28 PM
///M Power's Avatar
Quoted: 2 Post(s)
///M Power has a reputation beyond repute ///M Power has a reputation beyond repute ///M Power has a reputation beyond repute ///M Power has a reputation beyond repute ///M Power has a reputation beyond repute ///M Power has a reputation beyond repute ///M Power has a reputation beyond repute ///M Power has a reputation beyond repute ///M Power has a reputation beyond repute ///M Power has a reputation beyond repute ///M Power has a reputation beyond repute
how much are those aprts goign to run?
It might be more effective, and better in the long run (performance wise aswell) to just get a short shift kit.
///M Power is offline
post #9 of 10 (permalink) Old 04-18-2004, 05:28 PM
M3Daemon's Avatar
A simple SSK will make it a little bit better but it will not fix that problem completely, unless you get one of those very expensive ones which come with the selecting rod.
(I have a SSK installed that reduces shift throw by 30% and I still have that problem)
Daemon
<img src='
M3Daemon is offline
post #10 of 10 (permalink) Old 04-18-2004, 08:23 PM Thread Starter
CiscoKid's Avatar
thanx... and when i shift into 5th after the car has warmed up... it makes this noise... i cant really describe it, but the shifter rumbles.
CiscoKid is offline
Loose Seat Belt ajames 3-Series (E36) 0 08-07-2004 05:55 PM
Bad Shifting iantosca 3-Series (E36) 13 07-22-2004 03:14 PM
Shift knob loose mikester328 3-Series (E36) 6 07-13-2004 10:17 PM
loose nuts exjarhead328 3-Series (E46, E90) 5 04-01-2004 01:36 PM
