Looking for tips on fixing a convertible roof, clutch and other advice (1998 328i) - BMW Forum - BimmerWerkz.com
Old 03-25-2008, 08:21 AM   #1 (permalink)
Zone99 is an unknown quantity at this point
Hi,
I bought a 1998 328i Convertible (red, 34,500 mi, 5 speed manual) a few years ago and have absolutely loved the car. It's never seen snow, I put it away for the winter and it's so much fun that it makes up for me buying a 4 seater car for a 5 person family!
When I pull it out this year, though, I've been thinking about making a few changes and could use some advice:
1) The convertible roof: the roof works fine (mostly) and I've only had one problem with it where I had to manually crank it and get it fixed. The part that doesn't work is that the back of the roof doesn't come up far enough for the boot to get by it when I'm putting the roof down (the front goes back, the back of the roof lifts, the boot (?) comes up and then gets stuck on the bottom part of the back of the room).
I've been told by the BMW dealer that the elastics used stretch over time and that they need to be replaced. They changed these elastics out in the '99 and up versions.
The problem: $1500 for the repair. Now, while it's not SO bad reaching back and pulling the bottom of the roof forward, it is a bit of a pain.
Question: has anyone else encountered this and did you replace the elastics in the roof? What did you pay? Did you go to a dealer or did you try an place specializing in convertible roofs and tops?
2) The clutch: The clutch is hard to press and, in traffic, can get tiring. I'd like to replace it and make it easier to work. Are all BMW clutches like this though?
3) The brakes: One of the brakes squeals loudly. It's quite annoying when the top is down. I've taken it to a garage and they've said the brakes are fine. Any recommendations to get the squeal to stop?
4) The radio: the default radio is OK but I'd like better sound, especially when the top is down. I have the 6 CD changer. Any radio upgrade recommendations?
Thanks in advance!
Zone99 is offline   Reply With Quote
Old 04-01-2008, 06:22 AM   #2 (permalink)
peterSerbanica's Avatar
peterSerbanica is on a distinguished road
I replace tops and leather in New Jersey. The tension straps cost $200.00 from GAHH.com. Labor is around $350.00. You might want to consider a new top because top must be removed to replace tension straps. I also lubricate all joints of frame.
peterSerbanica is offline   Reply With Quote
Old 04-07-2008, 12:53 PM   #3 (permalink)
Peter,
Thanks for the reply.
Well, I'm in Mass. so that'd be a bit of a hike but, depending on where in NJ, it might be worth a try.
It stinks to have such a nice car and a roof that doesn't work right.
Based on your response, there's actually two choices then: replace the straps or replace the roof. Interesting. I'll have to think about that.
Thanks.
Old 04-08-2008, 09:49 AM   #4 (permalink)
dannydayz is on a distinguished road
Convertble Top Modificaton
YOu can Fix the convertible top without removing top or paying alot of money....go to store and purchase small bungie cords....the small ones that have balls on the end is preferable....cut the plastic balls off...you will have to tie ends of bungie cords on either side of convertible frame...this will get top to fold enough so that it will allow boot lid to close properly...
dannydayz is offline   Reply With Quote
Old 04-08-2008, 10:30 AM   #5 (permalink)
Ive seen that done...... only lasts a little while... waste of time imho
Old 04-08-2008, 10:36 AM   #6 (permalink)
Mr. Bacon
dannyb's Avatar
Car: '08 Rabbit / E30 325is
dannyb is a glorious beacon of lightdannyb is a glorious beacon of lightdannyb is a glorious beacon of lightdannyb is a glorious beacon of lightdannyb is a glorious beacon of lightdannyb is a glorious beacon of light
Send a message via MSN to dannyb
ltw flywheel with the new clutch?
Originally Posted by german-speed-demon View Post
that's my whore ; )
dannyb is offline   Reply With Quote
Old 04-09-2008, 11:11 PM   #7 (permalink)
my car is red
94BMW325i's Avatar
Car: 94 325i, 84 325e
CONVERTIBLES 101: My _____ Doesnt Work. How Do I Fix It??? - Bimmerforums - The Ultimate BMW Forum for your convertible needs.
I'm planning on fixing my 740iL - ADVICE/HELP? Elenar 1,6,7,8 - Series and Mini Cooper 1 12-22-2005 07:05 PM
1998 328i Fern Green Convertible bob1998ic Cars For Sale 7 07-21-2005 02:35 PM
328i 1998 - help and advice please lc1998 3-Series (E36) 1 09-09-2004 03:46 PM
1998 328i stalls occasionally with clutch Quickman59 3-Series (E36) 5 05-24-2004 10:24 AM
Convertible roof down PAUSTIN Bimmer Talk/Motorsports Talk 0 05-06-2004 01:17 PM
