LOCKED OUT!! - BMW Forum - BimmerWerkz.com
Old 10-04-2003, 01:38 AM   #1 (permalink)
rocco is an unknown quantity at this point
Got a 1995 325is and just locked my car keys in my trunk. Triple A towtruck and professional locksmiths have both failed and now I need some real help before I whip out the sledge hammer. ghead
The locksmith was able to get the hood open and access the fuse box but failed to open the central locking system.
Please help!!!!!
rocco is offline   Reply With Quote
Old 10-04-2003, 01:50 AM   #2 (permalink)
FruityOne's Avatar
FruityOne is an unknown quantity at this point
Send a message via AIM to FruityOne
well if you got an 325is...you should have fold down seats...so if you can get the doors open...im not sure how you would go about that...
93 325is - SOLD (white car in sig)
92 325i - 220rwhp/205rwtq (RIP)
02 GSXR 600 - 107rwhp/48rwtq
95 M3 - 220rwhp/205rwtq
President & Founder OF S50 Swap Club
THC the three most powerful letters in my veins...
FruityOne is offline   Reply With Quote
Old 10-04-2003, 03:33 PM   #3 (permalink)
Eggrolled211's Avatar
Eggrolled211 is an unknown quantity at this point
No spare huh....well if all else fails just sparkplug the rear side widow less damage and still pay for it with arm and leg...cuz its a BMW ehheheheh oh well good luck.
<img src='http://l00062.myspace.com/00062/50/89/62019805_m.jpg' border='0' alt='user posted image' />
Eggrolled211 is offline   Reply With Quote
Old 10-04-2003, 04:18 PM   #4 (permalink)
FruityOne's Avatar
as a last resort i say do this...find a junk yard and find the cheapest piece of glass you can get...and then go to your car and break that window and you should be able to get in and fold seats down and get your keys
Old 10-04-2003, 04:30 PM   #5 (permalink)
Defector
El Presidente's Avatar
ya know, you could just go the dealer and get a new key cheaper than a window.
And how did you manage to lock the keys in the trunk anyway?
Old 10-06-2003, 10:36 AM   #6 (permalink)
Hamann 325i is an unknown quantity at this point
i had a problem with my trunk locking all the time , as well as the doors. one of the mechanisms was jammed and causeed the door to lock once i truned the key to unlock it was weirds stuff
Hamann 325i is offline   Reply With Quote
Old 10-06-2003, 02:27 PM   #7 (permalink)
318i-Bmw is an unknown quantity at this point
I had the same problem yesterday........ all you need to do is find a coathanger and straighten it out completely. After that bend the end up about 2 inches and make the end where the bend is really small. Then gradually make it wider. Put a bend in the wire about 3/4 a foot up the wire from the bended hook on the end. This is used to allow the hook part on the end get back towards you where the lock is pushed down. Insert in the side of the door and push the part outside of the car towards the body of the car so that the hook comes back close to you once its inside the car. Slowly place the wide part over the lock and slowly pull it to the left and a little up. after it gets near the small part of the hook it will catch and pull up. Good luck
318i-Bmw is offline   Reply With Quote
Old 10-09-2003, 09:46 AM   #8 (permalink)
Walker is an unknown quantity at this point
anyone else scared that someone has that kind of information?
Walker, Texas Ranger....from New York..
Walker is offline   Reply With Quote
Old 10-09-2003, 01:47 PM   #9 (permalink)
Hahaha
Old 12-06-2003, 03:48 PM   #10 (permalink)
akumaninja is an unknown quantity at this point
I have a similar problem, with my '89 325is.
Some thief/vandal tried to pry open my trunk lock, and ruined the lock in the process. It cannot be opened with the key.
My boyfriend and I (with our chilton's guide) took a look at the wiring diagram, and found the leads coming from the central locking control unit, into the trunk lock actuator.
We stuck a switch between ground/unlock request...crossed our fingers...flipped the switch...and every lock in the car unlocked, _except_ for the trunk lock.
Seems that the electrical components of the trunk lock are shot. Thanks to that thief for bringing this to my attention!
Anyway, my question is this: Is there any MANUAL way to get the lock open? Mind you, the lock is so damaged, that the key cannot be inserted. Can I jimmy it with a coathanger? Hairpin?
If anyone can help, lemme know...
v
akumaninja is offline   Reply With Quote
Old 12-06-2003, 04:05 PM   #11 (permalink)
2.link's Avatar
2.link is an unknown quantity at this point
Send a message via AIM to 2.link
v
hmmm, first of all I would like to welcome you to the forums as we don't get too many women here.....DONT WORRY GUYS, I WONT CHASE HER AWAY!!!
So, it sounds like you will have to replace the cylinder in the trunk...check your fuses too about the trunk not unlocking, there might be a blown fuse....if not, something has gone wrong in the wiring...
If you can put the seats down and climb into your trunk with some tools....take off the tool thing....then take off the insulation stuff.....you will see the mechanism there and it should be pretty self explanitory how to open it....
Hope this helps...
<img src='http://www.european-forums.com/forums/uploads/post-1-1107198379.jpg' border='0' alt='user posted image' />
Formally known as Asio.
2.link is offline   Reply With Quote
Old 12-07-2003, 08:01 AM   #12 (permalink)
If I can get into the trunk, I can just manually pull the rod that would've been activated by the actuator in the first place, and unlock the trunk. It's just a matter of unbolting the seats and figuring out how to get in there. Doesn't look as easy as you've described. There's a layer of insulation, and then a large metal plate.
Not sure if the plate comes off or what. We could only peel back the seat so much.
Anyways...thanks for your advice. I've got my work cut out for me.
v
Old 12-07-2003, 08:15 AM   #13 (permalink)
2.link's Avatar
The seats just fold down....no metal plate....
Old 12-07-2003, 08:18 AM   #14 (permalink)
2.link's Avatar
Old 12-07-2003, 08:36 AM   #15 (permalink)
lol...I don't think we're talking about the same car.
1989 e30, 325is coupe.
Locked Out Of My Car!?? Electronic Lock Fails leetman 5-Series (E12,E28, E34, E39, E60) 4 08-01-2005 02:30 PM
Help- Trunk Locked Shut And Won't Open adamgui 3-Series (E21, E30) 4 06-11-2005 09:54 PM
E39 Gps Antenna And Monitor Locked simmymania 5-Series (E12,E28, E34, E39, E60) 1 05-29-2005 10:28 AM
Why The Hell Was The Rap Battle Locked?? leftone Video Vault 3 11-26-2004 12:20 PM
Ignition locked - HELP! 318ti Ray 3-Series (E36) 5 12-14-2003 03:41 PM
