Locked Hood - BMW Forum - BimmerWerkz.com
Old 12-25-2004, 10:29 PM   #1 (permalink)
falut is an unknown quantity at this point
I am very worried. I can not open my hood to refill radiator water. I had the engine running with a/c for 30 mins and did not realise the engine got very hot. How do I unblock the hood?...I have no idea how or when it got blocked.
falut is offline   Reply With Quote
Old 12-25-2004, 11:09 PM   #2 (permalink)
thekid's Avatar
have you already pulled the black hood release underneath the drivers side dash? For US cars it is against the drivers outside wall under the near the front, directly under the front of the dash... not sure if that was very clear but hopefully you go the idea. Then go around to the front of the Car and for US cars, the lever is slightly right of center just pull up and your hood is opened.
Old 12-25-2004, 11:36 PM   #3 (permalink)
Hello Sir,
I have had my BMW for over eight years. The black hood release lever seems to be working (like I can feel how it pulls the hood lock) but it does not open the lock.
At one point I thought that it was a safety issue. That the car won't let you open your hood if the engine is really hot. But it is cold now and nothing happens. It is a 96 BMW 328i. Take care.
Old 12-26-2004, 10:58 AM   #4 (permalink)
quality
Delmarco's Avatar
...for a minute there I actually thought this was a joke!
Run your fingers along the crevice of the hood I'm sure its something thats keeping the struts from sliding open...I had a similar problem when I installed a car BRA that connected to my hood struts...it jammed it in away that kept the hood from going up all the way....even though the lever under the dash popped the hood...
These struts are on the side by the way...also this advice is only if your hood pops open but doesn't rise all the way....
also a litlle Viagra in the fuel tank may help that hood rise!
but it should work
Old 12-26-2004, 11:00 AM   #5 (permalink)
quality
Delmarco's Avatar
[snapback]258328[/snapback]
And what are you doing putting water in the radiator? hopefully you were mixing it 50/50 with BMW only coolant.
And A/C on in the winter...ouch!
Old 12-26-2004, 11:54 AM   #6 (permalink)
thekid's Avatar
Ah yes, sorry I wasn't certain of what you were asking. So the lever does not pop the hood up at all? hmmm... maybe there is a way to take the handle off... I'm not sure though and unfortunately I can not look because my car is frozen shut...
Old 12-26-2004, 12:42 PM   #7 (permalink)
NeverLeaned is an unknown quantity at this point
Send a message via AIM to NeverLeaned
You can here the hook release pop when you pull the lever in the car?
YES----> Try the GM hood release trick! Very common problem on G-Bodies. With the ball of your hand, bang down on your hood (not to hard now!) Pushing the hood down, compresses the release spring..... a couple of good taps in the right area and the hood will release itself so you can slide your hand under to the secondary release.
1996- BMW 328IS
<img src='http://img.photobucket.com/albums/v242/gws226/TEX/neverleanedsig.jpg' border='0' alt='user posted image' />
Performance: Zimmerman Cross Drilled Rotors-- PBR Deluxes-- Cosmos CAI---- Turner Pulley Kit--- Fan Delete mod---
Beauty: 18 polished M-Parallel replicas, Inpro Euros w/ Enchanced Angel eye kit, 20% tint
Clear corners/sidemarkers ---- Eurospec (Depos)
To do list:
Suspension--- researching
UUC System U TDM- 3/05
M50 manifold converstion 3/05
NeverLeaned is offline   Reply With Quote
Old 12-26-2004, 10:39 PM   #8 (permalink)
Hello NeverLeaned,
Your idea worked perfectly. Thank you very much.
To follow up with my dramas, I added the radiator fluid and things seemed back to normal...but then I realised the engine overheated again and a major bang came along...losts of vapor and broken plastic parts ...damn... so sad. Tomorrow will see what the mechanics come up with...maybe the water pump is dead...I don't know...but mega problem it seems.
Old 12-27-2004, 07:37 AM   #9 (permalink)
Science Roolz!
Car: 2011 Mazda2, 1990 Miata
Originally posted by falut@Dec 26 2004, 10:39 PM
Hello NeverLeaned,
[snapback]258700[/snapback]
damn man i hope you get it fixed
2011 Mazda2
1990 Mazda Miata
Old 12-27-2004, 04:56 PM   #10 (permalink)
Hello SHAHAB323IS,
Thank you for your concern. My radiator has some broken plastic pieces. The problem started with a broken thermostat. Hope everything is fixed by tomorrow.
Getting a CF hood next week, concerns Autotechnica 3-Series (E36) 12 09-12-2004 02:48 PM
Help please...HOOD RELEASE REPLACEMENT lt247 3-Series (E36) 2 07-06-2004 10:33 PM
carbon fiber hood xad_theman 3-Series (E36) 10 06-25-2004 09:39 AM
New Hood Bmw1990 3-Series (E21, E30) 4 05-06-2004 06:00 AM
Finally got the hood off!!! steveo86 Bimmer Talk/Motorsports Talk 14 05-08-2003 01:58 AM
