| to tell if you have a lsd, the only way i know how to do it is to put your car on a lift (or anyway you can get both rear tires off the ground) then spin one of the wheels. If the other wheel (the one your not physically spinning) spins in the opposite direction, you don't have limited slip. If the other wheel spins the same direction as the one your spinning, you do have limited slip.
__________________ Mods: Tint, Euro Tails, Smoked corners and Side Markers, E46 Style Shadow Grill, 18" M3 Replicas, M3 Exhaust, Low Beam Silver Stars |
