Light Weight Flywheel.. - BMW Forum - BimmerWerkz.com
Old 12-17-2004, 12:46 AM   #1 (permalink)
theruss1an1's Avatar
Car: Needs momentum
theruss1an1 is an unknown quantity at this point
Send a message via AIM to theruss1an1
Uh.. I was going to get a light weight flywheel that would work with a m3 clutch. But my clutch died sooner than I hoped and I only had money for a stock clutch.. pooooooooooooooooooooop. ghead If I didnt get a new clutch Id be carless for month plus... and I got no way to get to work, so that was preaty much my only option. However, I still want a light weight flywheel. I called up bavarian autosports and they said their flywheel weights 15 pounds less than stock and can be used with my stock 325is clutch. But Im concerned with the flywheel being a single mass and it would work unlike a bmw should with a 325 clutch. Too much vibration. Does anyone know anything about the bav. auto flywheel or anyone else that makes a flywheel that would work with my stock 325 clutch. Thanks
-Serge
theruss1an1 is offline   Reply With Quote
Old 12-19-2004, 01:40 AM   #2 (permalink)
Car: Needs momentum
Anyone know anything on this?..
Old 12-19-2004, 01:51 AM   #3 (permalink)
Kevin325i's Avatar
Stock 325 clutch isn't what you want to be using. The thing is a piece of crap and will just slip after a couple hard launches.
If you're going to be taking it all apart anyways you might as well just go to the M3 or the UUC stage 2 set up and sell your old 325 parts.
Kevin (President TBEA)
Old 12-19-2004, 03:02 AM   #4 (permalink)
Car: Needs momentum
True.. 325is clutch does suck... even when new, I have had it slip a lot after few launches. Thanks for the advice Kevin. I was lookin at those stage 2 kits from uuc for a while, and I hear good things. I may as well start saving up... Cost is huge, but sounds too cool to pass up.
Old 12-19-2004, 07:28 PM   #5 (permalink)
Speedy-325is's Avatar
ltwt flywheels usually are a bit louder than stock. u will get used to it and it will dissappear. its good stuff yo.
Old 12-19-2004, 09:03 PM   #6 (permalink)
350z
Car: 03 Nissan 350z Track
try to do the install yourself you will save a lot!
David
**BAKER POW REPORT**
Old 12-19-2004, 11:29 PM   #7 (permalink)
thats not fun.
pulling a tranny is a Beehatch if ur doing it on the ground.
try to find a shop that will rent you a lift for a few hours. u have to know them, but its possible. sometimes....
Old 12-20-2004, 03:21 AM   #8 (permalink)
Car: Needs momentum
My auto class got a lift. When I put in my new clutch it took me about 7 -8 hours to do it. Next time when I put in flywheel and clutch I hope it be a lot faster, 5 -6 hours.
Old 12-20-2004, 08:49 AM   #9 (permalink)
I've tried to remove the tranny in my garage. It's pretty much impossible without a hoist. There isn't enough room under the car to drop the tranny. Once you somehow manage to drop the tranny, just remember you have to get it back up there and bolt it on! That's the hard part.
Anyways, I have an M3 flywheel/pressure plate for sale which is used. All you need is the clutch disc.
BTW all stock BMW clutch discs suck. They were made for people who granny shift like 40-50 year old men who can't drive. The M3 clutch disc is the more acceptable one. It actually bites with minimal slippage. It still slips more than I'd like, and I have a 318. The clutch is supposed to take 450hp? Anyways, if you like cruising around more than you like performance driving, stick to the stock clutches, an M3 clutch would be useless to you. A performance clutch can be quite brutal. If you start to fall asleep and your shifting gets a bit lazy and sloppy, you're going to feel some hard jerks. Stock clutches are best for traffic jammers and I suspect it's the reason why BMW clutches are so soft. They are easier to live with.
Bry
Abs/asc Light On 2000 523/525 Avatar1 5-Series (E12,E28, E34, E39, E60) 2 10-16-2004 08:49 AM
COMPUTER CHECK - TAIL LIGHT FAILURE?!?? kraze0g 3-Series (E36) 3 06-25-2004 10:30 PM
very light weight Lotus.... fatty Other Rides 4 07-21-2003 04:12 PM
