Light failures, please help - BMW Forum - BimmerWerkz.com
Old 10-06-2010, 08:32 PM   #1 (permalink)
w1nm is on a distinguished road
So recently my interior instrument panel and control lights went out. Basically everything that runs with the parking lights and head lights wont light up. On top of that I received a "tail light failure" on my check control. Everything works, break lights, turn signals, everything except for the actual tail light. Anyways I just finished replacing the Head Light switch and the only thing that fixed was the light in the actual switch that probably just needed to be replace anyways... Any suggestions of what it could be?
w1nm is offline   Reply With Quote
Old 10-07-2010, 12:49 PM   #2 (permalink)
Just an update, I've checked the wiring that runs from the trunk lid to the trunk and all the wires seem to be pristine so I guess I can rule out that? One other thing I've noted is that the buzz that reminds me I've left the lights on doesn't work as well. Please if anyone could point me in another direction it would be greatly appreciated!
Old 10-07-2010, 04:19 PM   #3 (permalink)
91bmw is on a distinguished road
I think this is a dead web site I am kind of having th esame problem with my 91 but it is just my head lights go out while driving and they are out for about 15 secs or so and then come back on. What I have read here though from other pepole is that there is an LCM and that is like the main brain for the lights but I have asked about it as well as where it is and get nothing so if you can find out that much I would try that first just make sure that when you find it you get it to match the year and model.
91bmw is offline   Reply With Quote
Old 10-07-2010, 04:59 PM   #4 (permalink)
Ich bin der Modifikator
johnnyBgood's Avatar
Assuming you checked all the fuses, I would check the wiring going directly to the tail light connector's , check the connectors for corrosion & clean.........
also check the tail light sockets & bulbs at the contact points for corrosion & burnt tips.........
check for proper ground.........in the trunk.
jb
Old 10-07-2010, 05:00 PM   #5 (permalink)
Well I've given up and I'm bringing the m3 into a nice local shop here, I'll let you know what the verdict is.
Old 10-07-2010, 05:01 PM   #6 (permalink)
Yup yup, no corrosion, I cleaned for good measure though. I've replaced a hand full of fuses just to be thorough yet nothing D:
Old 10-12-2010, 09:41 PM   #7 (permalink)
Final Verdict, Faulty wiring in the trunk. Even though most of the wires looked perfect it was a break in the wire at the base of the wiring harness connecting to the trunk lid. Patched it up fixed everything!
Old 10-12-2010, 09:48 PM   #8 (permalink)
Great to see it sorted!
Old 12-27-2010, 07:34 PM   #9 (permalink)
caodan2010's Avatar
caodan2010 is on a distinguished road
maybe u just need to add a resistor, go 2 like a lighting place
Oh, LED Bulbs!
caodan2010 is offline   Reply With Quote
bmw 525 tds 1994 injector light and glow plug light lit pockets666 5-Series (E12,E28, E34, E39, E60) 10 08-09-2009 04:45 PM
ABS light, brake light and TCS offline on 528i... ideas? rmory 5-Series (E12,E28, E34, E39, E60) 5 08-14-2008 10:01 AM
all bmw's common failures info.... LOS 5-Series (E12,E28, E34, E39, E60) 2 03-16-2006 09:09 AM
subframe failures: master techs, please help! peterkulesza 3-Series (E46, E90) 6 02-27-2006 11:40 AM
Check Engine Light & Air Bar Light blackstallion 3-Series (E36) 1 11-11-2004 11:53 AM
