| Be careful with this, too low resistance will burn fuses, while too small just won't cheat the computer. The wattage rating seems to be about 20W so this means a 7 Ohm resistor would do the trick. I personally would try the highest value resistor that still tricks the OBC.
Greg
__________________ Greg
97 328iS, Manual, Stock |
