| Leaking transmission cooler I removed trans cooler and replaced the two o-rings and that did not stop the leak. I was unable to pinpoint the leak, so I tried the o-rings first. I Pressure tested the cooler to about 20 psi and no leaks. What I'm wondering is what psi the transmission fluid is, in the trans cooler? Maybe I need greater pressure for testing for leaks? Car is 1994 325IC |
