leaking oil? - BMW Forum - BimmerWerkz.com
Old 05-28-2004, 01:36 PM   #1 (permalink)
IvanB's Avatar
IvanB is an unknown quantity at this point
Well, im trying to get rid of all the leaks on the car, and the oil leak is the worst.
when i bought the car, it had a thick coat of oil from the lower engine back to cat converter. old oil, new oil. the works.
the car was also 5 bottles of oil low. the previous owner had the car at the dealer, and at that time the technician said that it was leaking oil and that oil pan gasket probably needed be replaced, tran. fluid gasket too.
I got a quote from a mom and pop shop for $500 , ($490 labor $10 parts)
and then I got a quote from the dealer for $625. dealer is actually huge -- about 39 techs and they fix like 100 cars a day so I feel pretty comfortable in them not screwing it up too bad or at least making good on it if they do.
my question is, any way to fix the oil pan gasket without replacement? is there some oil additive that fixes leaks?
thanks mucho...oh by the way, I found place to clean to cars underbody for $36...looks really nice now! no more oil!
IvanB is offline   Reply With Quote
Old 05-28-2004, 03:06 PM   #2 (permalink)
ex owner/admin
Furious's Avatar
when the gasket is gone, your gonna have to replace it. if its leaking that bad that is.
Old 05-28-2004, 06:02 PM   #3 (permalink)
TeeUp's Avatar
Car: 2002 X5 3.0i and 2007 X5 3.0i
TeeUp is an unknown quantity at this point
bmw discourages the use of any oil additives or engine treatments as the use of normal oil, under any circumstance would be sufficient. also, the dealer says it may cause more harm than good, arguably that is....
TeeUp is offline   Reply With Quote
Changing Oil Filter Housing Gasket and O-Ring Live_the_Curves 3-Series (E36) 8 04-25-2010 01:34 PM
Help< Finally Figured Out Where Coolant Is Leaking BMW-ATI 3-Series (E36) 19 09-08-2008 07:15 PM
