Leaking coolant - BMW Forum - BimmerWerkz.com
Old 06-25-2006, 11:11 PM   #1 (permalink)
Leaking coolant
I have coolant leaking form (facing the engine) the top right side of the engine, right in between the electrical fuse box and the engine. Hope this isn't the head gasket area. Car runs for shorts distances, then I see steam coming out, so I haven't driven it anywhere.
Old 06-25-2006, 11:32 PM   #2 (permalink)
Anyone out there
Old 06-26-2006, 12:05 AM   #3 (permalink)
polaris448's Avatar
polaris448 is an unknown quantity at this point
that is kind of where the heater valve is, i think that is where you are talking about.
polaris448 is offline   Reply With Quote
Old 06-26-2006, 06:00 PM   #4 (permalink)
Threadkiller
bitcore's Avatar
There is a coolant line that goes to that general area to the engine block, take a look with a flashlight. Try removing your airbox to get a better look or get under your car.
If it's coming out of the engine block itself - uh oh.... take a pic and we can probably tell you exactly what's up.
Old 06-26-2006, 11:05 PM   #5 (permalink)
I took it the mechanic today, car slightly over heated but i turned it off right away, no damage was done. But at one point there was smoke inside the car. Mechanic is going to get back to me tomorrow with the exact problem.
Help< Finally Figured Out Where Coolant Is Leaking BMW-ATI 3-Series (E36) 19 09-08-2008 07:15 PM
Where does Coolant go? Delmarco 3-Series (E36) 20 03-15-2006 03:09 PM
Leaking Coolant uclabruins1996 3-Series (E36) 13 10-30-2004 09:01 PM
coolant dropping -- due to broken cap RedBeemer95 3-Series (E36) 3 09-12-2004 09:48 AM
Help, Coolant tank leaking walt525tour 5-Series (E12,E28, E34, E39, E60) 9 08-26-2004 09:39 PM
