Last Coolant Question - BMW Forum - BimmerWerkz.com
Old 06-10-2005, 09:35 PM   #1 (permalink)
Car: E30 318i, E30 318is, E30 M3
dvmotorsports is on a distinguished road
As we have already established I am not to familiar with "Ze German" cars.
I replaced the thermostat, o-ring, and gasket today.
It's still overheating. I ran some dye through the system and have a general idea where the other leak is coming from. The furthest I could trace it without pulling the car apart was to the AC Compresor. Maybe it is leaking from there.
Has anyone else experienced this problem? What is the proper course of action if it is the compressor (seals, full replacement)?
BMW Technician
dvmotorsports is offline   Reply With Quote
Old 06-10-2005, 10:00 PM   #2 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
You can replace the seals... just like anything else... it bolts up with a gasket type fitment... you can get this from the dealer... or an online parts dept. and replace as needed.
Les
1997 E36 M3 1990 E30 325i
Old 06-10-2005, 10:10 PM   #3 (permalink)
Can it be agreed upon that the AC is the only thing mounted in that area on an M42 that would leak coolant? Or is there something I'm not seeing?
BMW Technician
Old 06-11-2005, 09:08 AM   #4 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
I would honestly have to do some research to where the coolant travels around the A/C unit... I'm not sure it exactly goes around there or not...
How much fluid are you losing?... Big, small... puddle... ?
Get her hot... and look under the car while she is running... you might have to remove the under paneling.. in the front... but its worth a look... and see where it is coming from... get a mirror... search around.. thats the best way I've come to find leaks...
Good Luck,
Les
Old 06-11-2005, 10:49 AM   #5 (permalink)
Gator is an unknown quantity at this point
[snapback]352549[/snapback]
The AC system should not be responsible for a coolant leak. It contains freon (or some variant thereof) and not antifreeze. I'm not positive about your particular make of BMW, but is highly unusual for any AC mounting bolts etc to penetrate the block into the coolant system.
Gator is offline   Reply With Quote
Old 06-11-2005, 06:50 PM   #6 (permalink)
Originally posted by Gator+Jun 11 2005, 08:49 AM--><div class='quotetop'>QUOTE(Gator @ Jun 11 2005, 08:49 AM)</div><div class='quotemain'><!--QuoteBegin-dvmotorsports@Jun 10 2005, 09:10 PM
[snapback]352654[/snapback]
[/b][/quote]
That is what I was thinking. But I just can't figure out where it is coming from. I guess I am going to have to do the dye test.
BMW Technician
Coolant Question dvmotorsports 3-Series (E36) 6 06-10-2005 09:31 PM
Aux Water Pump/ Coolant Hoses Question? Ted K 5-Series (E12,E28, E34, E39, E60) 0 03-06-2005 10:52 AM
coolant dropping -- due to broken cap RedBeemer95 3-Series (E36) 3 09-12-2004 09:48 AM
E39 coolant level sensor NC540i 5-Series (E12,E28, E34, E39, E60) 4 05-27-2004 12:56 PM
Coolant Question charles01 3-Series (E21, E30) 1 03-06-2004 06:57 PM
