knocking noise at the rear wheels - BMW Forum - BimmerWerkz.com
Old 04-24-2009, 10:24 AM   #1 (permalink)
1fastm50's Avatar
Car: 84' 318i & 89' 750il
1fastm50 is on a distinguished road
theres a knocking noise in the driverside rear wheel. but it only makes the noise when i am turning to the left. at first i thought that the wheel was loose but its on there pretty good. i checked under the car to see if anything was loose but nothing was found. any advice
1fastm50 is offline   Reply With Quote
Old 04-24-2009, 11:16 AM   #2 (permalink)
PrInG's Avatar
Car: 95 Dakar Yellow M3, 00 1.8T VW GTI
PrInG has a spectacular aura aboutPrInG has a spectacular aura about
Send a message via AIM to PrInG
wheel bearing ? bad strut.. could be a multitude of things.
TO HONOR: Get Honor Stay Honor if You Can't Come in Her Come Honor.
"its not banana yellow but its not golden its just that perfect creamy german goodness"
- Bow
PrInG is offline   Reply With Quote
Old 04-24-2009, 09:35 PM   #3 (permalink)
Ich bin der Modifikator
johnnyBgood's Avatar
Also, check the rear trailing arm bushings....they are prone to fail..... when the bushings fail, the trailing arm knocks against the rear subframe of the car........ links below:
Symptoms of bad trailing arm bushings include side movement of the rear end under acceleration, general looseness of the rear over bumps, and abnormal tire wear. These bushings will start wearing out after about 50,000mi, give or take. As you'll see in this DIY, I made a special puller/press tool for dealing with this stubborn bushing, but it wasn't good enough for removal. So I had to go butcher style, which is an option many choose instead of paying out your ass for the tool.
BMW E36 RTAB Without Special Tools
E36 RTAB DIY with BMW Tools w/ or w/o GC shims - Bimmerforums - The Ultimate BMW Forum
johnny,
Old 04-30-2009, 10:33 AM   #4 (permalink)
carbonfiber dream's Avatar
Car: 1999 bmw e-36 m3
carbonfiber dream is on a distinguished road
if u have after market wheels it may be the lug hitting the e-break. thats happened 2 me. if thats the case get it out quick or u can shred the e-break set up. other then that check ur bushings.
carbonfiber dream is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Knocking Noise bimmer318is 3-Series (E36) 0 12-16-2005 10:23 AM
Metallic Friction Noise At Rear Wheels mostwired 3-Series (E36) 1 08-25-2005 07:19 PM
e34 knocking noise from engine d3ity 5-Series (E12,E28, E34, E39, E60) 8 07-14-2004 12:45 AM
Knocking Noise CaptainEL 5-Series (E12,E28, E34, E39, E60) 5 01-26-2004 09:22 AM
noise out of front and rear driver's wheels debbie M-Series (M1, M3, M5, M6) 5 11-22-2003 05:25 AM
