Knock Sensor... - BMW Forum - BimmerWerkz.com
Old 11-26-2004, 01:58 AM   #1 (permalink)
sy5alive is an unknown quantity at this point
Got a check engine light a few days ago. Turned out to be Knock Control
Test Sensor and Knock Sensor #2. I put in new gas and cleared the codes.
They have not reappeared since.
Should I be worried at all about this? Will this come and bite me in the ass? If so, what precautionary measures should I take to avoid any future problems related to this?
Thanks,
Tommy
'94 318is
sy5alive is offline   Reply With Quote
Old 11-26-2004, 11:31 AM   #2 (permalink)
Threadkiller
bitcore's Avatar
It could have just been a bad tank of gas of low octane to cause the knock sensor to throw a code, or the sensor could have malfunctioned and the computer threw a code.
I'm really not sure, you'll have to get an answer from someone here who has much greater knowedge of what those codes COULD mean. Was the engine acting funny when the codes were thrown? making any funky noises, shaking, etc?
Old 11-26-2004, 01:00 PM   #3 (permalink)
Nope, no rattles or shakes. Only codes it threw were the two knock sensor-related ones.
Old 11-26-2004, 03:16 PM   #4 (permalink)
/Banned
91notchback's Avatar
91notchback is an unknown quantity at this point
[snapback]237873[/snapback]
if you get this again i would recommend putting 93 octaine in and bringing it to a dealership, not shure what type of pistons they use, but if they are Hypereutectic pistons they will crack with very little detination. even if the arnt its still very bad for the motor
91notchback is offline   Reply With Quote
Old 11-27-2004, 10:58 AM   #5 (permalink)
Threadkiller
bitcore's Avatar
yes. Be sorta weary until it happens again. If it dosn't happen again withen a month, just keep putting the recomended octane or higher in and keep doing that. Don't buy anything less than mid-grade [I forget the number]
BMW engines run at a high compression so they need a higher octane so they don't knock. It dosn't mean you need premium, you just need what's listed on the gas cap flap thingy.
Old 11-28-2004, 01:50 AM   #6 (permalink)
thanks dudes
Old 11-29-2004, 01:47 PM   #7 (permalink)
DesmoBob's Avatar
if the problem keeps coming back after driving a month with the higher octane, the sensor may be bad.
common sensor problem is they crack. replacement of the sensor itself isn't hard, the most PITA part is removing the intake manifold, although i am unfamiliar with m42/m40, so i don't know if that's necessary in your case.
Old 11-29-2004, 01:54 PM   #8 (permalink)
dagoo98 is an unknown quantity at this point
Thanks,
Tommy
'94 318is
[snapback]237623[/snapback]
Cheap gas is the common cause of this problem. My uncle also used to use cheap gas until he saw the check engine light come on as a result of his frugal spending. Hope that you learn from this also. If you use cheap gas in these cars to try and save money you will end up paying more in the long run on engine repairs.
dagoo98 is offline   Reply With Quote
knock sensor Lunardc 3-Series (E36) 3 11-05-2005 03:26 PM
Knock Sensor? sy5alive 3-Series (E46, E90) 1 11-19-2004 01:48 PM
Check Engine Light came on today camnipotent 3-Series (E36) 22 05-17-2004 06:23 PM
New Car - Few Problems, Any Help Appreciated. Sagan 3-Series (E36) 8 05-16-2004 09:28 PM
