keyless remote - BMW Forum - BimmerWerkz.com
Old 07-19-2004, 01:02 PM   #1 (permalink)
Car: 2002 BMW 745Li
Eraj is hated around these parts
Send a message via Yahoo to Eraj
Hey guys,
I installed a "Bulldog" keyless entry system in my 94 320i. (Yeah, me vewy cheap) Will a BMW remote off ebay (I mean remote in the key) work with this type of cheap ass keyless entry system? Or do they use different frequencies/signals etc?
I used the pre wired harness behind the glovebox.
Thanks for your help
Eraj
2002 BMW 745 Li.
Eraj is offline   Reply With Quote
Old 07-19-2004, 04:09 PM   #2 (permalink)
Defector
El Presidente's Avatar
No. The factory key is programmed to work with the factory alarm only.
Old 07-21-2004, 12:17 PM   #3 (permalink)
Car: 2002 BMW 745Li
One more question,
After I connected the aftermarket keyless brain to the pre-wired harness by splicing the wires, each time I used the remote to unlock the car, an alarm started going (lights blinking for 10 seconds) At this point I had to find a wire called FASD (Factory alarm system disable), fish around to match it with a wire from the harness to stop the flashing lights.
Does this mean I already had a factory alarm????
and, If I did, is it not connected to the harness, or do I have the alarm and the pre-wired harness as well?
I'm confused...please help.
Thanks
Eraj
2002 BMW 745 Li.
Old 07-21-2004, 04:52 PM   #4 (permalink)
frank3 is an unknown quantity at this point
your car came pre-wired to install a factory remote by simply pluggin in the "brain" to the wiring harness at the plug which is located behind the glove box. If your plug didn't have the "brain" attached, then there was no factory alarm installed.
<span style='color:green'>1994 325i </span>- - - 75,000 mi.
No mods - - - very happy as is!
<span style='color:green'>1995 525i </span>- - - 154,000 mi.
No squeaks or rattles... unreal!
frank3 is offline   Reply With Quote
Keyless Remote Help Needed Please.. superglide09 3-Series (E21, E30) 6 04-01-2005 06:07 PM
Curious If I Can Put Keyless Entry And Remote .... Cloxe 3-Series (E36) 6 01-20-2005 02:12 PM
Two part numbers for same keyless remote? frank3 3-Series (E36) 3 10-31-2004 06:44 PM
my stock Alarm, i lost hte Keyless remote WickedBimmer 3-Series (E36) 3 02-04-2004 06:55 PM
KEYLESS ENTRY REMOTE PROBLEM.... torrienta 3-Series (E36) 2 01-02-2004 10:24 AM
