Keyless Entry/Alarm remote trouble - BMW Forum - BimmerWerkz.com
Old 07-22-2006, 05:14 PM   #1 (permalink)
Car: 1997 BMW 318i
rwall23 is an unknown quantity at this point
Send a message via MSN to rwall23
Ok, I bought a keyless entry/alarm remote off of ebay and figured out how to program it from instructions on the internet, but I'm having trouble. I cant get my car to initiate the code learning sequence. I did the open your trunk, open the door, sit in the seat, close the door, toggle the igniton from off to pos. #2 five times within 10 seconds etc. thing and it doesnt seem to be working, any suggestions?
rwall23 is offline   Reply With Quote
Old 07-22-2006, 10:38 PM   #2 (permalink)
What brand did you buy?
What was the brand that you bought?
The Stellars are plug-n-play no hassle....
Mike
Hamfisted is offline   Reply With Quote
Old 07-22-2006, 11:33 PM   #3 (permalink)
Car: 1997 BMW 318i
its just an OEM BMW remote because I already have the BMW alarm system
Old 07-22-2006, 11:37 PM   #4 (permalink)
/Banned
preyash's Avatar
Car: Audi
preyash preyash preyash preyash preyash preyash preyash preyash preyash preyash preyash
Send a message via AIM to preyash Send a message via MSN to preyash Send a message via Yahoo to preyash
HAHA
You dont have to do that programming like that, you will have to take the glove compartment off and find the keyless receiver, it has a small door u gotta open it it has a place where u put a chip in. Then, open ur remote and take the chip out and put it in the receiver and press the little button next to it, the red light will light up i mean the light near the heated seats buttons and next to the lighter, then take the chip out and put it back in ur remote and see if it works, then ur done, enjoy ur keyless entry.
It works fine for me.
By the way any more questions post em...
Preyash
preyash is offline   Reply With Quote
Old 07-27-2006, 09:52 PM   #5 (permalink)
jorber's Avatar
jorber is an unknown quantity at this point
Lightbulb did it work?
I want to know if the remote you bought work, I want to buy one but I don't know exactly what fcc id i must buy. my keyless module is A269ZUA070, i found that is a remote that is A269ZUA071 probably this one is its couple, but also I found another one that is fcc id A269ZUA111 (newer than the other one).
wich one did you buy?
I found that ther is the same fcc id but for a SAAB used:
see:
http://cgi.ebay.com/ebaymotors/ws/eB...MakeTrack=true
http://cgi.ebay.com/ebaymotors/BMW-K...QQcmdZViewItem
http://www.fcc.gov/Bureaus/Engineeri...cation-1991.db
http://www.fcc.gov/Bureaus/Engineeri...cation-1996.db
jorber is offline   Reply With Quote
Old 07-28-2006, 03:04 PM   #6 (permalink)
Car: 1997 BMW 318i
I don't see a chip that I can take out, do you? And I called the dealership they said some are programmed with a chip and some are programmed by the method I tried. so HAHA right back to you... ass
Keyless Entry/Alarm remote trouble-dscf0019.jpg
Old 07-28-2006, 09:39 PM   #7 (permalink)
Many different models...
There were many different model security systems available as dealer options on the E36 cars. Are you sure that's the correct FOB for your system? Because that rain dance you described above doesn't jive with what the factory TIS instructions are for programming a new FOB. Have you pulled your panel from below your glovebox and looked at the security brain box to make sure it's a BMW box? Take the part number off it if you can. The factory BMW alarm FOBs I've seen for the E36 was on the ignition key. If all else fails I would just buy a Stellar alarm from Autowerks.com so you know you have a complete compatible system. The Stellar RTX is plug-n-play into the E36 alarm plug. They also offer the tilt/shock sensor which the BMW alarm didn't have.
Mike
Keyless Entry Problems - single button remote stevellion 3-Series (E36) 0 02-12-2006 01:43 PM
Keyless Remote Help Needed Please.. superglide09 3-Series (E21, E30) 6 04-01-2005 06:07 PM
Two part numbers for same keyless remote? frank3 3-Series (E36) 3 10-31-2004 06:44 PM
keyless remote Eraj 3-Series (E36) 3 07-21-2004 04:52 PM
KEYLESS ENTRY REMOTE PROBLEM.... torrienta 3-Series (E36) 2 01-02-2004 10:24 AM
