Just installed my M3 rear trailing arm bushings - BMW Forum - BimmerWerkz.com
Old 04-25-2004, 06:28 PM   #1 (permalink)
My mechanic says that if the bolt positions are kept the same while he reinstalls the trailing arm, the alignment settings should be preserved.
However, when the bushing is removed and a new one is installed, the bushing obviously is not in the exact same position. So when the trailing arm is reinstalled, wouldn't there be a change in alignment settings? There is also significantly less play with this newer stiffer M3 bushing. My old bushing was cracked and came off the casing completely. If any of you are replacing rear trailing arm bushings, get the M3 ones. They are so much stiffer and better. My rear end comes around so easily now. I can actually get some throttle induced oversteer (steering with the throttle).
Thanks, any help would be appreciated. I only ask this because my steering wheel seems to have moved slightly to the right about 2-3 degrees. There is no noticeable vibrations on the highway at high speeds. I don't want to wear my rear tires funny as they are brand new.
Thanks,
Bry
Old 04-25-2004, 08:32 PM   #2 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3
The rule is, Whenever you touch the suspension< YOU HAVE TO ALIGN.
Yeah you need to align.
Old 04-25-2004, 09:05 PM   #3 (permalink)
ex owner/admin
Furious's Avatar
i would bry
Old 04-25-2004, 09:46 PM   #4 (permalink)
Threadkiller
bitcore's Avatar
Steering wheel is off a few degrees? Something is not correct.... Go get an alignment.
///M Power said it best. F with the suspinsion, Align your wheels because they will be slightly off.
E36 Suspension Work, Want To Upgrade Suspension? victorgallas Product Reviews 8 02-08-2005 08:21 AM
Installed Convertable Rear Shock Mounts.. BMWJNKY 3-Series (E21, E30) 3 02-04-2005 08:41 PM
E30 Rear Trailing Arms On A E21? seanman914 3-Series (E21, E30) 1 12-29-2004 08:51 PM
