just bought a bimmer, need advice - BMW Forum - BimmerWerkz.com
Old 03-12-2006, 10:34 PM   #1 (permalink)
Pirtle 3 is on a distinguished road
my dad bought me a bmw for graduation, it is in pretty good condition but has alot of miles on it.
95 325is auto
129,000 miles
my question is what are the first things i should do to it to make sure it last for as long as possible? im sure this is a stupid question and im sorry for taking all of your time but i dont really know where to start
Pirtle 3 is offline   Reply With Quote
Old 03-12-2006, 10:42 PM   #2 (permalink)
Power Shifting
Cruzin 323is's Avatar
tune up and constant oil changes every 3000 miles...
if u see a problem arising, get it fixed asap.. or it will make it much worse...
BTW...
lets see some pics??
-SOLD..
R.I.P Fast 6
Old 03-13-2006, 04:19 AM   #3 (permalink)
General Chaos
SpeedInfusion's Avatar
Car: ///M3,Corolla
Inspection 2
Old 03-13-2006, 02:49 PM   #4 (permalink)
walshja is an unknown quantity at this point
what you need to do is visit a mechanic and have them change ALL the fluids in the car: oil, transmission, coolant, brake fluid. that will protect your brake system, cooling system, and drivetrain.
that's the best thing you can do for your car, and it will set you up for the next few years, and you will know exactly when they have been changed. do not assume they have been changed recently or ever.
then start changing your filters: air filter, cabin filter, fuel filter and transmission filter (if automatic).
let us know what you do !!
1994 325iC, 130k miles
walshja is offline   Reply With Quote
Old 03-13-2006, 08:13 PM   #5 (permalink)
e36surge's Avatar
Welcome to the board. INSPECTION 2 (YES) and welcome to the following repairs that will arise in the next few months (if they haven't been replaced already)
1) rear shock mounts
2) rear bearings
3) rear trailing arm bushings.
4) front bushings, bearings and tie-rods.
Try to take a look underneath the car. Do an exhaust inspection (visual) and check to see if the heat shields are peeling off (shiny things between exhaust pipes and bottom of the car.
I got my 1995 325is with similar mileage last may and the above mentioned issues arose for me. I AM NOT SAYING THIS WILL HAPPEN TO YOU but just advising you that these issues may arise.
Good luck, great car. HAVE THE TRANNY OIL CHECKED ASAP.
- Mario Andretti
1979 320is RiP
1994 318is Sold
1995 325is Sold
1995 530i Sold
2004 M3
Old 03-13-2006, 08:48 PM   #6 (permalink)
I am Teh Edumacator.
Teh Prof's Avatar
Replace the water pump using one with a metal impeller. The stock pump has a plastic impeller that fails suddenly and causes huge overheating problems.
Replace the thermostat and thermostat housing; make sure the new thermostat housing is an aluminum one.
Consider replacing the coolant overflow tank, its holes tend to get clogged over time and cause reduced coolant flow and therefore cooling efficiency. The plastic neck on your radiator may one day crack; if so, replace it with a radiator that has an aluminum neck. If you have the cash, you might even replace it pre-emptively.
Go to auto-rx.com, and run their treatment.
You treat your bimmer right, and it will treat you very well. Treat it badly, and you'll have nothing but problems.
Lindsay fan club member.
Old 03-14-2006, 03:24 PM   #7 (permalink)
thanks for all the quick replies, sorry i havent replied in a couple days ive had a very busy work schedule. Thank you very much for all the info, i will try to get all of that done as soon as possible money allowing. Also i will put pics up asap. e36surge, thank you for the imput and i sympathise with you lol, hopefully i wont have to go through the same thing
Old 03-14-2006, 06:42 PM   #8 (permalink)
catalyst. is an unknown quantity at this point
Send a message via AIM to catalyst.
Theres really on doubt that you will.
The suspension is tight on bmw's and therefore wears out quickly, replacing the control arms, control arm bushings, tierods, trailing arm bushings, etc, needs to be done periodically (anywhere from 10k miles to 50k miles depending on how aggressivly you drive) to create a tight and smooth ride, they should be considered *wear* items such as brakes.
catalyst. is offline   Reply With Quote
Old 03-15-2006, 06:01 PM   #9 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3
Do this first.
Old 03-15-2006, 09:19 PM   #10 (permalink)
e36surge's Avatar
LOL my suspension *wears* a lot faster than my brakes...
I just bought a 95 740iL - overheated - advice? Elenar 1,6,7,8 - Series and Mini Cooper 4 11-29-2005 10:53 PM
Need Advice About A/c In E34 Just Bought. bimerguyCW 5-Series (E12,E28, E34, E39, E60) 0 06-11-2005 06:37 PM
Bought '95 530ia W/ Rebuild Eng, Need Advice bimerguyCW 5-Series (E12,E28, E34, E39, E60) 6 06-02-2005 08:26 AM
Just Bought An 87, Need Some Advice RainWind 3-Series (E21, E30) 7 04-28-2005 11:49 AM
So I Bought My Dad A Used Bimmer Bimmer Picture Showroom 12 04-08-2005 01:22 AM
