Jingling Noise Heard When Hitting A Bump - BMW Forum - BimmerWerkz.com
Old 01-25-2005, 10:39 AM   #1 (permalink)
BMWspeedracer is an unknown quantity at this point
Send a message via AIM to BMWspeedracer Send a message via MSN to BMWspeedracer
So yeah, when I hit a bump or something, I hear this jingling type of noise.
I was wondering if anyone had this before and figured out what it was.
Any ideas would be greatly appreciated.
1992 325i.
Former Nissan 240sx owner...
Now BMW owner...
and not missing the 240 too much
BMWspeedracer is offline   Reply With Quote
Old 01-25-2005, 10:43 AM   #2 (permalink)
93 325i's Avatar
Is the noise coming from the rear? Probably a rear shock mount
Complete mod list and pics:
My 1993 325i
Old 01-25-2005, 10:57 AM   #3 (permalink)
yeah, I think it might be coming from the rear.
My car sounds like santa and his reindeers ghead
Now BMW owner...
Old 01-25-2005, 12:10 PM   #4 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
You can pull the carpet like stuff in the back away with little problem... just put your rear seats down.. pull back the linning.. and have someone gently push down on each rear corner.. if you see your crap moving all around.. then its time to replace your RSMs...
Good Luck,
Les
BTW www.rogueengineering.com sells some good ones... as does www.turnermotorsports.com
1997 E36 M3 1990 E30 325i
Old 01-25-2005, 12:39 PM   #5 (permalink)
ex owner/admin
Furious's Avatar
personally for shock mounts, get your hands on the ground control rear shock mounts. they are sooo good, urathane bushing, they have two settings, race and street.
, also id check the rest of the car, for loose or broken parts on the suspension, like sway bars, the links for the sways etc etc
Old 01-25-2005, 01:37 PM   #6 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
The rogue engineering RSMs have the ability to fit either 10mm shocks or 12mm race shocks...
haha,
Les
Old 01-25-2005, 01:53 PM   #7 (permalink)
BMDub325is is an unknown quantity at this point
I think I may know the answer to your problem. Mine has a jingly noise too. It sounds like it comes from the rear suspension. It only is noticable when you hit small sharp bumbs. I was reading around on another forum and a guy said that wrong brake clips are ofter installed in the e36. I have not checked mine yet but you should be able to take the wheel off and wiggle the brake pad to see if this is the problem. If it is you can fix it for 5 or so $ I'm sure. Good luck
92' 626 ES
88' Mazda Truck
92' VW passaat (sold)
93' BMW 325is
86' BMW 318is
<img src='http://www.geocities.com/bmdub325is/images/current/signaturefinal2.JPG' border='0' alt='user posted image' />
<a href='http://www.geocities.com/bmdub325is' target='_blank'>***MY E36 BUILDUP PAGE***</a>
BMDub325is is offline   Reply With Quote
Old 01-25-2005, 02:09 PM   #8 (permalink)
wonderful ideas. Keep 'em comin. I will check on all those when I get home.
Now BMW owner...
Old 01-25-2005, 02:35 PM   #9 (permalink)
---318is---'s Avatar
---318is--- is an unknown quantity at this point
You know what- this problem might be simpler than you think. I had the same
problem with my bimmer. All it is, is that little stones fall into the undertray(the plastic panel under the engine) and bounce around when you hit bumps. Just lift you car and hit the undertray and reach for them with your hand. If not, then it most probably is your shock mounts.
318is 1.9 16v
Remus exhaust
K&amp;N air filter
Tinted windows
18s M3 alloys
Bilstein suspension kit
Bosch super4 spark plugs
---318is--- is offline   Reply With Quote
Old 01-25-2005, 05:42 PM   #10 (permalink)
diezel99's Avatar
diezel99 is an unknown quantity at this point
Send a message via AIM to diezel99
I've had the same jingling problem with my 92 325i.....it turned out to be the exhaust heat shield and the clamps holding it on.....jingle jingle over the bumps, easy fix. Good Luck
diezel99 is offline   Reply With Quote
Ever Heard A Clicking Noise From Inside Dash? bimmerfan620 3-Series (E36) 8 03-04-2005 03:23 PM
Ticking Noise From Engine Clint_M 3-Series (E36) 9 11-07-2004 11:02 AM
loud noise - including clicking tsinghbmw 3-Series (E36) 6 06-01-2004 02:25 PM
