issue swapping 95 m42 into 92 chassis - BMW Forum - BimmerWerkz.com
Old 03-04-2010, 06:19 PM   #1 (permalink)
artic318is is on a distinguished road
i motor went found a great deal on a 95 m42 swapped over full harness, dme, and coils. went to start and nothing. starter just clicks, will not turn over. not sure if this could be caused by the ewsII or not. does not have the #66 pin so i'm stumped there. is it possible that if i use my old harness, coils, and dme it may fix the problem. please help need insight!!
artic318is is offline   Reply With Quote
Old 03-11-2010, 03:59 AM   #2 (permalink)
Car: 1997 328i touring
dudehog is on a distinguished road
hmmmm. firstly check the battery is ok (sorry to state the obvious), secondly check the earthing strap (on a uk spec as you look at the front of the engine it is on the left hand side at the front at the bottom. big thick brown cable, can't miss it). take it off at both ends and give it a good clean with a dab of copper grease over it. this happened to mine after the engine change, another tell-tale sign of this for me was the windows didn't have enough of a good connection and did sod all. give that a go and let us know.
the dude.
dudehog is offline   Reply With Quote
95 318ti motor in 93 318is chassis??? Brealnfla 3-Series (E36) 0 11-06-2009 08:29 AM
Chassis And Transmission Rigidity e36_415 3-Series (E36) 4 02-08-2005 05:45 PM
Missing Chassis Stiffener? bal4833 3-Series (E36) 3 10-12-2004 12:44 AM
e36 m3 swap into e30 chassis Scarface 3-Series (E21, E30) 16 02-10-2004 08:05 AM
z3 chassis code FlorIt_Z3 1,6,7,8 - Series and Mini Cooper 3 09-23-2003 12:01 PM
